Hi all... wondering if there is anyone out there that could suggest the
best way to remove the passenger window to take photos... I know about unscrewing the retainer from the window... but just wanted to know if there are any points to watch out for .. best speed etc... The plane is not mine..and the flight school wouldn't be too thrilled if a)I told them what I was planning to do b) came back with a broken or REALLY scratched side window Thanks to all, )Simon |
best way to remove the passenger window to take photos... I know about unscrewing the retainer from the window... but just wanted to know if there are any points to watch out for .. best speed etc... First, I don't really believe you want to REMOVE the window...just allow it to open to allow you to shoot through the window opening. Second, the retaining parts vary on different models, so be careful with the parts. Also, many of the 150/152/172s have long since lost the screw, so it may not be an issue. Third, don't rest your arms, elbows or the camera on any part of the airframe, keep the camera back inside the cabin out of the slipstream, etc., etc. On some Cessnas, you'll want to put some tape or slip a piece of hose over the door-holding-open thingie on the underside of the wing to prevent damage to the window in the fully open position. Now, the important part... in flight, grasp the window latch firmly as you open the window, hang on tightly and SLOWLY open the window until it is held against the bottom of the wing by the slipstream. Finally, I shoot aerial photos at a SAFE altitude, typically 1500' agl and at low cruise speed - none of this slow flight, flaps down stuff. |
Simone Canosa wrote: I know about unscrewing the retainer from the window... but just wanted to know if there are any points to watch out for .. best speed etc... It shouldn't give you any problems. When you open the window, hand onto the latch and open it fully. The airstream will fold it up until it is nearly touching the bottom of the wing. The aircraft will attempt to turn right, and you will have to apply nearly full left aileron. The aircraft will also pitch up a little and require you to adjust the trim. Expect to lose about 5 knots of airspeed. Make sure that there are no light items (such as charts) loose in the plane before opening the window. I never tried opening both windows in my Cessna, but it's possible that this would reduce the amount of rudder pressure required, with a possible further reduction in speed. The best camera angle will be shooting forward between the strut and door frame. Keep the camera inside the plane. If it's not an autofocus (or maybe even if it is), set the focus on infinity and use it as a point&shoot. It is possible to crab the plane to get the wing up out of the way for photos, but you don't have much left rudder available. Plan on no more than half an hour of shooting before your left leg gives out. I would avoid using lens larger than about 100mm unless you have one of those gyroscopically stabilized units. I would recommend using a good camera strap, just in case. George Patterson Some people think they hear a call to the priesthood when what they really hear is a tiny voice whispering "It's indoor work with no heavy lifting". |
"G.R. Patterson III" wrote: It shouldn't give you any problems. When you open the window, hand onto the latch and open it fully. The airstream will fold it up until it is nearly touching the bottom of the wing. The aircraft will attempt to turn right, and you will have to apply nearly full left aileron. The aircraft will also pitch up a little and require you to adjust the trim. Expect to lose about 5 knots of airspeed. I've opened windows in 150/152/172/182 and 206 and never noticed any roll or need for any aileron and for certain "nearly full" aileron was not needed. Even with the jump door open on the 182 and 206 rudder or aileron is not needed. Was something else going on to cause you to need aileron? -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
Same here, fixed wing or swing wing.
PJ -- =============== Reply to: pj at offairport dot com =============== Here's to the duck that swam a lake and never lost a feather, May sometime another year, we all be back together. J.J.W. ========================================= "Dale" wrote in message ... In article , "G.R. Patterson III" wrote: It shouldn't give you any problems. When you open the window, hand onto the latch and open it fully. The airstream will fold it up until it is nearly touching the bottom of the wing. The aircraft will attempt to turn right, and you will have to apply nearly full left aileron. The aircraft will also pitch up a little and require you to adjust the trim. Expect to lose about 5 knots of airspeed. I've opened windows in 150/152/172/182 and 206 and never noticed any roll or need for any aileron and for certain "nearly full" aileron was not needed. Even with the jump door open on the 182 and 206 rudder or aileron is not needed. Was something else going on to cause you to need aileron? -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
"G.R. Patterson III" wrote in message
... The aircraft will attempt to turn right, and you will have to apply nearly full left aileron. The aircraft will also pitch up a little and require you to adjust the trim. Expect to lose about 5 knots of airspeed. I haven't had this effect in a 172. I would avoid using lens larger than about 100mm unless you have one of those gyroscopically stabilized units. I went flying last Wednesday after theConcorde flight. I had my (father's) camcorder with me so I set up the tripod in the back of the plane. Strange thing. The camera (Sony) has "image stabilisation", no giros or anything, not sure how it works, something floating inside the camera or just a digital effect more likely. Anyway, it's most noticable on taxying. The plane bobs up and down over the rough ground but the image shows the horizon as steady with the instrument panel moving up and down. Saw this fly a wide circle around me, put its wheels down and set itself up on long final to Boscombe Down as I was climbing out from Thruxton: http://www.paulnann.com/images/pn_w1402.jpg Paul |
Hmmm, I was reading about taking pictures from planes and most recommended a
300mm lens.. crab the plane to get the wing up out of the way for photos, but you don't have much left rudder available. Plan on no more than half an hour of shooting before your left leg gives out. I would avoid using lens larger than about 100mm unless you have one of those gyroscopically stabilized units. Real good idea! I would recommend using a good camera strap, just in case. |
CVBreard wrote:
Third, don't rest your arms, elbows or the camera on any part of the airframe, keep the camera back inside the cabin out of the slipstream, etc., etc. That's so there isn't any vibration transmitted through the airplane to the camera. If you do need to rest it against any piece of the plane, use a bean bag, which will dampen any vibration and stabilize it. Finally, I shoot aerial photos at a SAFE altitude, typically 1500' agl and at low cruise speed - none of this slow flight, flaps down stuff. http://www.ntsb.gov/ntsb/brief.asp?e...12X17575&key=1 I used to know this airplane's previous owner (not the one who was killed) |
I'm surprised no one has mentioned the "paperwork" associated with removal
of window.. it's great that everyone always mentions opening the window once in flight... For "removal" of the window and then flying sans window.. would that not require a Form337 and approval? To open the window once flying is not a problem.. just remember to hang on until it stabilizes in the slip stream.. and if it's a bumpy day.. it could slam down on your arm.. healthy slipstream also at 80-100mph I once had a passenger in a C-172, feeling a bit warm in the bumps decided he needed air to alleviate his queasiness.. and with no warning he unlatched the window.. the resultant BANG.. got my attention.. power to idle.. my first thought was a prop failure or a bird strike.. 1 second later I realize his window is open.. after collecting my thoughts... I gently reach over and closed it.. (it had stopped on the window limit braces and not slammed up against the bottom of the wing) and the showed him the wing root fresh air vents and put it full force on him. BT "Simone Canosa" wrote in message ... Hi all... wondering if there is anyone out there that could suggest the best way to remove the passenger window to take photos... I know about unscrewing the retainer from the window... but just wanted to know if there are any points to watch out for .. best speed etc... The plane is not mine..and the flight school wouldn't be too thrilled if a)I told them what I was planning to do b) came back with a broken or REALLY scratched side window Thanks to all, )Simon |
Thanks to everyone... tons of usefull information,
Cheers Simon BTIZ wrote in message DTyzb.2505$yf.2101@fed1read01... I'm surprised no one has mentioned the "paperwork" associated with removal of window.. it's great that everyone always mentions opening the window once in flight... For "removal" of the window and then flying sans window.. would that not require a Form337 and approval? To open the window once flying is not a problem.. just remember to hang on until it stabilizes in the slip stream.. and if it's a bumpy day.. it could slam down on your arm.. healthy slipstream also at 80-100mph I once had a passenger in a C-172, feeling a bit warm in the bumps decided he needed air to alleviate his queasiness.. and with no warning he unlatched the window.. the resultant BANG.. got my attention.. power to idle.. my first thought was a prop failure or a bird strike.. 1 second later I realize his window is open.. after collecting my thoughts... I gently reach over and closed it.. (it had stopped on the window limit braces and not slammed up against the bottom of the wing) and the showed him the wing root fresh air vents and put it full force on him. BT "Simone Canosa" wrote in message ... Hi all... wondering if there is anyone out there that could suggest the best way to remove the passenger window to take photos... I know about unscrewing the retainer from the window... but just wanted to know if there are any points to watch out for .. best speed etc... The plane is not mine..and the flight school wouldn't be too thrilled if a)I told them what I was planning to do b) came back with a broken or REALLY scratched side window Thanks to all, )Simon |
| Thread Tools | |
| Display Modes | |
