Have a student question...
Old August 1st 12, 03:11 AM posted to rec.aviation.piloting
Robert Barker
Default Have a student question...
Cessna 172SP. Mfg/Cert after 1998. As you know, there is no MEL for this
aircraft. VFR day flight. Nav/position lights. Say the bulb is out on the
starboard position light.
91.206 says nav/position lights are not mandatory for VFR day flight.
91.213(d) comes into play since there is no official MEL for this aircraft.
Can I fly this aircraft in VFR day flight? Do I need to placard the burned
out bulb?
It's questions like this that kept me out of the better schools... ;-)
Old August 1st 12, 04:32 AM posted to rec.aviation.piloting
Dave Doe
In article , cowboy_bob99
@hotmail.com, Robert Barker says...
out bulb?
I'm sure someone more knowledgable may know for sure, but the MEL
doesn't, AFAIK, cover things like basic nav lights.
To me, yes, you definately need working nav lights - and if you're
flying in a dense traffic area, turn on *all* your lights - landing
lights etc - if you're carring a Christmas tree, turn those lights on
too
Duncan.
Old August 1st 12, 05:13 AM posted to rec.aviation.piloting
Robert Barker
This is not really a question of what you should do, but more of what the
FAA requires. Yes, I normally fly with it all on, but here in Colorado, it
really doesn't help much as it's so bright most of the time anyway (IFR is
when I take off from KAPA and can't see Long's Peak 65 miles to the north!).
And, yes, the MEL doesn't apply which is why 91.213(d) comes in.
"Dave Doe" wrote in message
this
aircraft.
burned
out bulb?
too
Duncan.
Old August 1st 12, 05:17 AM posted to rec.aviation.piloting
Orval Fairbairn
out bulb?
too
Nav lights are not required for day VFR. Some airplanes have no lights
at all.
Old August 13th 12, 09:05 AM posted to rec.aviation.piloting
MJ
On Tue, 31 Jul 2012 20:11:56 -0600, Robert Barker wrote in
Do I need to placard the burned out bulb?
You need to replace it.
Old August 13th 12, 03:51 PM posted to rec.aviation.piloting
On Tuesday, July 31, 2012 9:11:56 PM UTC-5, Robert Barker wrote:
Cessna 172SP. Mfg/Cert after 1998. As you know, there is no MEL for this aircraft. VFR day flight. Nav/position lights. Say the bulb is out on the starboard position light. 91.206 says nav/position lights are not mandatory for VFR day flight. 91.213(d) comes into play since there is no official MEL for this aircraft. Can I fly this aircraft in VFR day flight? Do I need to placard the burned out bulb? It's questions like this that kept me out of the better schools... ;-)
Robert,
Two things must be considered he the FARs, and the aircraft certification. There is no FAR that requires navigation lights for day VFR. As for the aircraft certification, look in the back of the POH. There you will see a list of items/equipment for the aircraft. If the item is marked mandatory/required, then you must have it. Otherwise, it's not required.
csel, cmel, cses, cfi-a, cfi-i, agi, igi
Student pilot certificate question Jeffrey Bloss Piloting 2 October 27th 09 12:30 AM
question on student taxi practice Mark Piloting 105 April 13th 06 12:00 PM
Question from a new flight student (whopping 7 hours!) Gary G Piloting 90 October 21st 04 11:48 PM
Student-Instructor question (USA) Nolaminar Soaring 18 December 1st 03 06:25 PM
Instrument Fix Question (student) Cecil E. Chapman Instrument Flight Rules 6 August 11th 03 07:15 PM
