WinPilot and Mini Map II
Old August 15th 12, 02:43 PM posted to rec.aviation.soaring
Dave Springford
Default WinPilot and Mini Map II
Is anyone out there running Winpilot Pro on the LX mini map?
Do you need the PNA version of Winpilot, or with the Win CE 5 on the Minimap, does the PDA version still work.
Anyone have it connected to a 302? Do you still get all the air data from the 302 that you had on the PDA?
Old August 15th 12, 11:01 PM posted to rec.aviation.soaring
Richard[_9_]
On Wednesday, August 15, 2012 6:43:22 AM UTC-7, Dave Springford wrote:
Is anyone out there running Winpilot Pro on the LX mini map? Do you need the PNA version of Winpilot, or with the Win CE 5 on the Minimap, does the PDA version still work. Anyone have it connected to a 302? Do you still get all the air data from the 302 that you had on the PDA? Thanks,
WinPilot ADV will run on the MiniMap, I don't think WinPilot Pro, needed for a vario installation will run, WinPilot decided not to support the Platform.
Richard
www.craggyaero.com
Old August 16th 12, 01:53 AM posted to rec.aviation.soaring
Darryl Ramm
You would need the PNA version since Windows CE is missing lots of Windows
Mobile bits needed for the standard PDA version. Supporting Windows CE is
the whole point of the PNA release. However talk to folks who actually gave
this running to make sure everything works OK.
Richard at Craggy Aero is likely the best person to talk to for this.
Darryl
Old June 9th 13, 01:01 PM posted to rec.aviation.soaring
Alexander Müller
Am Donnerstag, 16. August 2012 00:01:50 UTC+2 schrieb Richard:
Richard
www.craggyaero.com
Hi Richard,
I try to get the WinPilot PRO Version running on my LX MInimap PRO. Jerry gave my passwords for the PNA PRO 12 and 13 version, but I have no links where I can donload the necessary files. The links on the WinPilot homepage guide to a PRO 10 Versions (for which I have no password) or to a ADV 12 version (that I don´t want to use). Can you help me? It is very difficult to get support from Jerry...
Regards
Alexander
LX Mini Map Andrew Blanchard Soaring 36 March 8th 14 04:07 AM
mini-map Gaetan Trudel Soaring 4 November 22nd 10 04:40 PM
Mini-Imp Curt Fennell Home Built 7 November 10th 09 12:43 PM
Mini Imp Randall Robertson Simulators 3 December 17th 03 05:56 AM
WinPilot Offers Free WinPilot XP for your Desktop Computer Richard Pfiffner Soaring 0 November 8th 03 04:44 PM
