Hi all,
yesterday I was landing with a C182T , when in very short final , at least 30 pigeon took off directly to myself . They were very close to me ,few inches I guess .My decision was to do nothing, continue and land . Fortunately all pigeon were skill enough to avoid my plane at least for one inch . My friend and pilot seated on the right seat desagree with me and told me full power and go around . In his opinion a collision in short final with low power setting ,could have cause setting the plane to the ground . In his opinion with full power the plane should had succesfully resist the strike or strikes . Is this right ? Is a safe procedure to set full power , in case of bird encounter ? thanks pablo |
Curt Johnson wrote: On 8/31/2012 3:39 AM, wrote: Is this right ? Is a safe procedure to set full power , in case of bird encounter ? pablo I hit a duck on short final in a Grumman AA-1B. I barely felt it, although it put a good sized dent in the leading edge of my right wing. A few pigeons are not going to bring down a 182. If you see birds approaching your flight path and you have sufficient time to calmly react, it wouldn't hurt to go around, but if it's a last second decision, you are better off taking a few nicks than over-reacting and risking a stall/spin. Curt Best move (if you have time) is to climb immediately, as an airplane can easily outclimb a bird. If you have a collision, continue the approach and land, since you really won't know the extent of the damage (if any) until you are safely on the ground. Impacts at approach speeds are likely do do minimum (if no) damage, Hitting birds at cruise can make sone big holes in airframes. I have seen vulture impacts that: 1. penetrated to the main spar on an SX-300 2. crushed a wingtip on a Seneca 3. destroyed the left cowl and made big dent in the firewall on a Bonanza. |
Hi All
thanks for your comments , I agree over-reacting is worse . Pablo |
| Thread Tools | |
| Display Modes | |
| Final Approach, pt 3 - KFME final.jpg (1/1) | Mitchell Holman[_3_] | Aviation Photos | 0 | April 8th 09 01:56 PM |
| The BIRDS | Kyle Boatright | Piloting | 29 | March 5th 06 12:50 PM |
| Amelia Earhart fans flock to Iowa! | Jay Honeck | Home Built | 5 | October 12th 03 08:23 AM |
| Amelia Earhart fans flock to Iowa! | Jay Honeck | Owning | 5 | October 12th 03 08:23 AM |
| Amelia Earhart fans flock to Iowa! | Jay Honeck | Piloting | 5 | October 12th 03 08:23 AM |
