ASW27 tail wheel
Old September 1st 12, 05:29 AM posted to rec.aviation.soaring
pat
Default ASW27 tail wheel
Does anyone know where to get an extra heavy tail wheel to move the
Cof G rearwards?
Old September 1st 12, 08:28 AM posted to rec.aviation.soaring
Tim Taylor
If in the US:
http://www.wingsandwheels.com/page32.htm
Old September 1st 12, 12:06 PM posted to rec.aviation.soaring
joesimmers[_2_]
John Murray also stocks them.
Old September 4th 12, 03:13 AM posted to rec.aviation.soaring
John Godfrey (QT)[_2_]
I filled my tailwheel with foam. Added 2.4 lbs. Cost about $20 as I
recall.
Old September 4th 12, 03:15 AM posted to rec.aviation.soaring
John Cochrane[_3_]
I filled my tailwheel with foam. *Added 2.4 lbs. Cost about $20 as I
recall.
Lead foam? I don't get it. Foam seems pretty light. What kind of
foam?
John Cochrane
Old September 4th 12, 04:47 AM posted to rec.aviation.soaring
John,
I've filled a tail wheel with foam. It was done at a local truck tire shop.
The foam is rubber which is quite heavy. The 2 to 2.5 lb. weight increase
is correct for a standard glider wheel. The increase on the little Matco
WHLTW35 wheel I installed on my HP-14 was only 0.5 lbs.
http://www.soaridaho.com/Schreder/Co.../DSCN2618.html
"John Cochrane" wrote in message
recall.
foam?
John Cochrane
Old September 10th 12, 03:46 PM posted to rec.aviation.soaring
Cof G rearwards?
I'm interested in a swap. I have a brass tail wheel and need a standard one. Send me the details on yours if you're interested. I'll look up the axle size on mine.
Juan
juanman at mac dot com
ASW tail wheel Dan Mockler Soaring 8 July 31st 12 05:26 PM
ASW tail wheel Dan Mockler Soaring 0 July 28th 12 09:53 PM
Blanik Tail Wheel Roy Bourgeois Soaring 2 August 21st 07 12:56 PM
Brass tail wheel Solo Soaring 9 July 6th 07 04:18 PM
FS: Blanik L-13 Tail Skid & Tail Wheel Assembly Tim Hanke Soaring 0 February 8th 05 01:34 PM
