IGC FR Serial number
Old September 5th 12, 05:41 PM posted to rec.aviation.soaring
Andy[_1_]
Default IGC FR Serial number
The TECHNICAL SPECIFICATION FOR GNSS FLIGHT RECORDERS includes these
definitions and requirements relating to the serial number:
"FR Serial Number (S/N) - For an IGC FR, a set of three alphanumeric
characters allocated by the manufacturer (unique tothat manufacturer),
identifying an individual FR. The S/N appears in the first line of the
IGC file. If identification of an individual FR is required, the S/N
should be prefixed by the manufacturer's name and followed by the FR
model and type."
"Serial Number (S/N) – The three-character Alphanumeric identifier for
an individual IGC Flight Recorder. This appears as a three-character
group in the name of IGC files and also in the first line of the IGC
file. Although the word "number" is used, a more accurate term would
be "numbers and letters". Non-IGC recorders may have different S/N
systems."
"2.2.6.1 Identification Markings. The case of an IGC recorder must be
permanently marked with the name of the
recorder manufacturer, the type and version and the three-character
alphanumeric serial number (S/N) of that recorder. Where a display is
available, the recorder make, type, S/N and version must be shown on
that display for at least 10 seconds before it changes to another
presentation, so that it can easily be written down by an OO before
flight. Other details on the display are optional because many are
included in the IGC file header record. Where a recorder is designed
to be mounted in an instrument panel, the above data must be easy to
see and record from the cockpit without having to access the back of
the panel."
"3.10 First lines of IGC files - Serial and Version Numbers. The first
line of the IGC file contains a manufacturer
identification and a three-character alphanumeric Serial Number (S/N)
unique to that Recorder. The H- (header) record of the IGC file must
also include the version number of hardware, firmware, and details of
the GPS receiver and Pressure Altitude sensor (see Appendix A paras
3.1 and 3.2)."
"A2.5.3 FR Serial Number (S/N). For IGC FRs, the three-character S/N
must be used in the A-record and be imprinted on the case of the
recorder unless the case includes a display which includes the S/N.
See the definition of Serial Number in the Glossary."
For the two Cambridge flight recorders I own (302 and 25) the FR S/N
is visible externally on the unit and is not changed when the unit is
serviced or repaired.
Is there any legitimate circumstance in which the FR S/N assigned
during manufacture would be changed when the unit is serviced or
repaired? Such a change would appear to conflict with - "The case
of an IGC recorder must be permanently marked with the name of the
alphanumeric serial number (S/N) of that recorder. "
Reason for the question is as follows:
Power FLARM brick FR S/N is identitifed by a marking on the unit
seal. My unit was defective on receipt and was repaired by the US
repair center. It was returned with a new seal covering the cut
original seal, and that new seal bears a different FR S/N.
I have no way of knowing how the unit is identified in the log file as
the flight recorder function is not yet enabled.
thanks
Andy (GY)
Old September 5th 12, 05:44 PM posted to rec.aviation.soaring
Andy[_1_]
model and type."
systems."
alphanumeric serial number (S/N) of that recorder. *Where a display is
the panel."
3.1 and 3.2)."
repaired? *Such a change would appear to conflict with * - "The case
seal. *My unit was defective on receipt and was repaired by the US
repair center. *It was returned with a new seal covering the cut
original seal, and that new seal bears a different *FR S/N.
thanks
Andy (GY)
Correction - the unit in question is a Portable not a Brick.
Andy
Old September 5th 12, 06:10 PM posted to rec.aviation.soaring
Andy[_1_]
manufacturer),
model and type."
for
systems."
is
the panel."
first
3.1 and 3.2)."
Power FLARM portable FR S/N is identitifed by a marking on the unit
as
thanks
Andy (GY)
Old September 5th 12, 08:09 PM posted to rec.aviation.soaring
Jim[_32_]
manufacturer),
model and type."
for
systems."
is
the panel."
first
3.1 and 3.2)."
as
thanks
Andy (GY)
I think using one (or both) of these commands in your config file will dump a file which includes the unit's serial number. I don't remember but you can't hurt anything giving it a try.
$file,dump
or
$debug_out,fat,all,all
-Jim
Old September 6th 12, 03:17 PM posted to rec.aviation.soaring
Andy[_1_]
$file,dump
or
Jim,
The hardware serial number for the portable is shown in menu/info/
about. The displayed hardware serial number matches the part number
label as has not changed.
The IGC serial number is not displayed in the menus and is not
included in the dump file. It should of course be included in the
flight log if there was a logger function. The hardware serial number
is included in the dump file.
I have now been advised by FLARM USA that the IGC serial number is
changed every time the unit is opened and resealed. That doesn't seem
to meet the intent of the IGC specification but, if that's an issue,
it will be resolved when the logger is enabled and IGC approval is
requested.
Andy
BTW - Sorry for any confusion that I caused by deleting my first two
posts. The first post had an error, the second post corrected the
first post, the third post repeated the first post but without the
error, and then I deleted the other two. The result is ok on the old
Google group viewer but the deleted posts still show up in other
viewers.
Recorder Serial Number Dan Marotta Soaring 5 December 16th 11 01:31 AM
FAA Withholds Pre-9/11 ID Confirming Aircraft Serial Number Data Of 9/11 Planes Private Piloting 1 January 8th 08 07:48 PM
How get get serial number of GNS-430? Andrew Gideon Owning 15 September 26th 05 11:49 PM
How get get serial number of GNS-430? Andrew Gideon Products 15 September 26th 05 11:49 PM
B29 tail serial number Tarakan WW2 Joanne Smedley Military Aviation 6 August 13th 03 02:11 PM
