Battery Power
Old September 23rd 12, 11:26 PM posted to rec.aviation.soaring
Mike McCarron[_2_]
Default Battery Power
Help!
I have carefully measured my current draw in my glider at .8 amp. l would
like to know if there is any reasonable explanation for why a 9 amp hour
battery goes from 13 volts open circuit fully charged to 11.6 volts in 4
hours.
MC
Old September 24th 12, 12:10 AM posted to rec.aviation.soaring
Tom Gardner[_2_]
Mike McCarron wrote:
Help!
hours.
Short answer: 9AH is the nominal capacity, the actual capacity
depends on temperature, discharge rate and battery age..
Long answer: have a look at the graphs in, for example,
http://www.standbattery.com/linkfiles/Technology%20Manual.pdf
Old September 24th 12, 12:32 AM posted to rec.aviation.soaring
Mike McCarron[_2_]
Help!
would
hour
4
hours.
Could not find the graphs. Brand new battery and very reliable battery
charger.
Mike McCarron[_2_]
Help!
would
hour
4
hours.
charger.
Old September 24th 12, 12:34 AM posted to rec.aviation.soaring
Mike the Strike
Also, 0.8 amps is about double the load the battery is rated for. The capacity of your 9 A.h battery should be about 10 hours at 25 degrees C. Your battery sounds cold or tired or both!
Plus, do you ever use your radio?
Old September 24th 12, 01:05 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Help!
would
hour
4
hours.
charger.
Fully charge the battery, then do a discharge test at about 0.8 amps.
Even a new battery can be defective, so I always do a discharge test on
new batteries before using them in the glider.
It could also be the charger. Have you tested it's charging ability
recently?
email me)
Old September 24th 12, 01:07 AM posted to rec.aviation.soaring
Mike McCarron[_2_]
Where does it say that I should only draw 400 ma? The battery is brand new
and fully charged. Open circuit wasr 12.0 to start.
What is the problem?
Old September 24th 12, 02:14 AM posted to rec.aviation.soaring
Mike McCarron[_2_]
new
As a correction to the above I meant to say the open circuit voltage was 13
volts when I started everything up. I do use the radio as little as
possible.
Old September 24th 12, 02:57 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
800 ma isn't too much to take from the battery. It will reduce the
capacity about 10% from the 400 ma, ~20 hour rate used to measure the
rated capacity.
email me)
Old September 24th 12, 04:30 AM posted to rec.aviation.soaring
Mike the Strike
The 9A.h batteries I use would have a rated capacity of about 8A.h at a current of 0.8A - that's about ten hours' worth. Dropping the temperature to freezing will drop that to about 7 to 8 hours - still more than you're getting.
Also remember that the current drawn by some devices may increase as the voltage drops. I'd suggest checking your current draw at a range of battery voltages.
If your charger's ok, it sounds like your battery isn't.
Battery Power Mike McCarron[_2_] Soaring 13 September 27th 12 06:22 PM
battery power regulator Tony V Soaring 17 August 10th 11 05:39 AM
Oshkosh Camping - Battery Power Tom McQuinn Owning 3 June 11th 07 12:19 AM
Power setting table and best economy/best power... xerj Piloting 29 October 20th 05 02:44 AM
battery charger to get through Piper power port? Kyler Laird Owning 16 March 20th 05 12:08 AM
