Aerobatics in semi acrobatic certified sailplanes
Old October 3rd 12, 03:17 PM
jams jams is offline
Junior Member
First recorded activity by AviationBanter: Oct 2012
Default Aerobatics in semi acrobatic certified sailplanes
Hi all,
I have recently become interested in gliding and have been exploring the aspects associated with the sport.
I'm going to use the term 'standard glider' to represent any non-acro 15m glider, (ASW 19/20, Speed Astir, LS range, DG range, PIK20D etc) not standard class.
I recently started looking at aerobatics and sailplanes certified for this. Started looking at datasheets for aircraft and most 'standard gliders' are semi aerobatic only, in addition to this some give g ratings. The most common I have found is +5.3 / -2.65. Seems to be almost a standard.
When I started looking at what maneuvers 'semi acrobatic' gliders could perform, the standard list seems to be loops, spins, chandelle, spiral dive.
I then came across some more advanced maneuvers like cuban 8, barrel rolls, inverted flight etc. I thought that these type of maneuvers would exceed the -g rating of -2.65, so wouldn't be feasible. Then I came across this you tube footage of a PIK20D doing some, what I think to be, serious aerobatics.
http://www.youtube.com/watch?v=tSB-JAFqrhU
Pretty sure there is some significant -g going on in some of these moves, however the PIK20D (according to the BGA datasheet) is only rated to -2.5g.
So what I'm asking is:
Is this still basic stuff, (just looks impressive too me!)?
What sort of -g would be experienced in these maneuvers, would it exceed -2.65?
Would other 'standard gliders' be able to do stuff like this (assuming they had the same g rating as the PIK)?
I did think for a minute that this was a brave chap wondering what it would take to snap the wings off, but on translating the German it says its part of his bronze acro training. So it must be signed off by some CFI somewhere?!
What do you think?
One interesting thing I came across was the g ratings for the
LAK-12...+6 -4...thats quite high up the g rating ladder, and pretty impressive for an 20.5m Open class machine!
Cheers
James
Acrobatic simulators Jake Simulators 0 July 28th 07 10:58 PM
Non-certified parts for a certified plane? Dico Owning 10 August 22nd 06 03:11 AM
Acrobatic Homebuilt? [email protected] Home Built 2 May 16th 05 07:01 AM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 05:36 PM
Va and negative g's & fun non-acrobatic maneuvers Koopas Ly Piloting 44 December 5th 03 02:03 AM
