Komet surge brake
Old October 23rd 12, 03:24 AM posted to rec.aviation.soaring
Tony V
Default Komet surge brake
I need to replace the surge brake damper on my 1986 Komet III trailer.
I'm wondering if someone out in ras land has a part number (or
equivalent) and replacement instructions. It appears that Entec, the
former Komet US representative, is no longer active.
I've seen Bruce Greeff's write up for Eberle trailers -
http://www.standardcirrus.org/Trailers.php
thanks in advance
Tony "6N"
Old October 23rd 12, 02:38 PM posted to rec.aviation.soaring
Dave Nadler
thanks in advance
Tony "6N"
Hey Tony - Why do you think the damper is the problem ?
Usually its not (just adjusted another trailer 2 weeks ago)...
See ya, Dave
Old October 24th 12, 12:04 AM posted to rec.aviation.soaring
Tony V
thanks in advance
Tony "6N"
Because I can activate the surge brake by hand by simply pushing the
coupler back and forth a few inches. There's hardly any resistance.
See ya, Dave
It would be nice if I was wrong. :-)
Tony
Old October 24th 12, 02:33 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
thanks in advance
Tony "6N"
If the dampner is shot, the trailer brakes will slam on and then release about twice per second when the tow vehicle is braking, making a chirping sound as your tires are eaten up..................ask me how I know
JJ
Old October 24th 12, 03:49 PM posted to rec.aviation.soaring
Wheaton
Go on the trailer tongue and check the information on the data plate, probably Knott Ghb trailers. they are Komets source for these parts. Then send me an email so I can talk to through it. Easy once you know the drill. There are also adjustment instructions on Knott Ghb web site. I have a name in Germany with email who were terrific in working with me. pa12joe at aol..com.
I finally got a response from the Komet people with a price and it was considerable more costly.
JJB
Old October 25th 12, 12:27 AM posted to rec.aviation.soaring
Tony V
thanks in advance
Tony "6N"
JJ
Yup! I've learned to brake gently. That helps but.....
Tony, LS6-b "6N"
Old October 25th 12, 12:29 AM posted to rec.aviation.soaring
Tony V
On 10/24/2012 10:49 AM, Wheaton wrote:
Go on the trailer tongue and check the information on the data plate, probably Knott Ghb trailers. they are Komets source for these parts. Then send me an email so I can talk to through it. Easy once you know the drill. There are also adjustment instructions on Knott Ghb web site. I have a name in Germany with email who were terrific in working with me. pa12joe at aol.com.
Thank you! I will be visiting the trailer soon. :-)
Tony
JJB
Old October 25th 12, 03:24 AM posted to rec.aviation.soaring
C2
thanks in advance
Tony "6N"
Mark Mocho in Moriarty completely rebuilt my surge brake from scratch last year. I suspect there are only a few people who can do what he can do. If you are anywhere near Moriarty go see Mark.
Cobra surge brake again db_sonic Soaring 6 July 17th 09 02:12 AM
Greasing Al-Ko Surge Brake rlovinggood Soaring 3 March 17th 09 04:29 AM
Hydraulic trailer surge brakes means no parking brake? [email protected] Soaring 11 March 18th 08 04:19 AM
Eberle Surge Brake Rebuild Jim Hendrix Soaring 0 June 18th 04 08:28 PM
Air Force Academy seeing surge in applications Otis Willie Military Aviation 0 January 31st 04 03:55 AM
