Flarm and ADS-B antennas
Old October 29th 12, 01:26 AM posted to rec.aviation.soaring
Andrzej Kobus
Default Flarm and ADS-B antennas
I am puzzled by what was delivered with my brick. Flarm antenna
ANT-916-MHW-RPS-y and another antenna ANT-916-MHW-SMA-y (this one came
with a note that is was ADS-B antenna and it had a blue heat shrink
close to the connector). I am puzzled that they both are for 916 MHz
frequency. Is something wrong with this picture? Should the ADS-B
antenna be 1090 Mhz? It looks to me that the only difference between
them is a connector one is RPS and the other one is SMA. I can't
believe this is right.
Old October 29th 12, 04:37 AM posted to rec.aviation.soaring
bumper[_4_]
Andrzej,
From what I've seen earlier bricks came with the ADS-B/PCAS antennas you discribe. Later bricks are shipping with a shorter dipole that is more tuned for the 1090 Mhz frequency. The only differance in the two antennas is that the radials on the 1090 antenna are a little shorter (gueestimating each radial is 3/16" shorter). Flarm had to special order the higher frequency antennas . . . they are from the same company that makes the 916 Mhz antenna, but are not an off-the-shelf item.
One could heat the little ribber cap to remove them and then lop off a bit of the radial with a Dremmel cut-off wheel after doing the math. But in the real world, the 916 Mhz antenna should work pretty well as receive is much less critical than transmit. That and the fact that the signal you are receiving is being transmitted at 200 watts.
bumper
Old October 29th 12, 10:25 AM posted to rec.aviation.soaring
Andrzej Kobus
On Oct 29, 12:37*am, bumper wrote:
Andrzej,
bumper
I would not think PowerFlarm would special order anything if it was
not required. Why would they change the antenna later, maybe because
of poor PCAS performance? If PCAS estimates distance through signal
strength (as I was told) then how would they be able to calculate the
strength with two different antennas?
Old October 29th 12, 03:01 PM posted to rec.aviation.soaring
Andy[_1_]
There is provision in the ADS-B module interface for calibrating for
different antenna performance. However, I have no way of knowing if
units delivered with the later antenna are calibrated differently.
( See TRX-1090 Data Port Specification)
Andy GY
US Power FLARM Antennas Andy[_1_] Soaring 13 June 21st 12 07:34 AM
Antennas! Get yer antennas here! Bob (not my real pseudonym) Aviation Photos 0 March 3rd 11 04:38 AM
Antennas [email protected] Home Built 1 February 19th 09 07:32 PM
Antennas Terry Home Built 3 April 24th 05 06:42 PM
Antennas Terry Home Built 3 April 22nd 05 03:14 AM
