Video from Day 1 of Region 4 North 2012
Old October 30th 12, 08:10 PM posted to rec.aviation.soaring
Sean F (F2)
Default Video from Day 1 of Region 4 North 2012
Video here --- https://vimeo.com/52396659
Side note: Interesting PowerFLARM warning in at the 9:13 point of this video.
The glider that bumped directly thru this thermal (about 20 ft. below me) will go unnamed. I am not claiming he/she did anything wrong at this point. But...this happens often to me OFTEN in contests. My understanding is that contest pilots should not fly directly at another glider established in a thermal and should NOT do their pull-up at such close proximity. I had to change my direction significantly to stay in a position that I considered safe.
My understanding is that a contest pilot MUST do their pull-up outside the thermal and blend in safely from the side of the thermal in a safe, predicable and benign manner. This is rarely the case in my experience. The glider in the thermal should have, for lack of a better work, the RIGHT OF WAY. But many, many do the straight in attack run technique in the contest environment. It can be very distracting. I have another video of a couple "incident's" at this summer's Sports Class Nationals that were far, far, FAR worse. Ill may put those up at some point in the future.
How would the rules committee govern this? How can this be enforced, if it is improper technique or unsafe according to the standards the rules committee has set? What are the consequences for unsafe flying and how does one prove that they have been subjected to an unsafe pilots poor technique (or worse)? Seems like the onus is, unfortunately on me. Seems like the wild west at times. I see no disciplinary action happen to pilots who cause, for example, collisions.
My goal is to better understand where the line is drawn and what I should expect and not expect.
Old October 31st 12, 01:37 PM posted to rec.aviation.soaring
On Tuesday, October 30, 2012 4:10:58 PM UTC-4, Sean F (F2) wrote:
Video here --- https://vimeo.com/52396659 Side note: Interesting PowerFLARM warning in at the 9:13 point of this video. The glider that bumped directly thru this thermal (about 20 ft. below me) will go unnamed. I am not claiming he/she did anything wrong at this point. But...this happens often to me OFTEN in contests. My understanding is that contest pilots should not fly directly at another glider established in a thermal and should NOT do their pull-up at such close proximity. I had to change my direction significantly to stay in a position that I considered safe. My understanding is that a contest pilot MUST do their pull-up outside the thermal and blend in safely from the side of the thermal in a safe, predicable and benign manner. This is rarely the case in my experience. The glider in the thermal should have, for lack of a better work, the RIGHT OF WAY. But many, many do the straight in attack run technique in the contest environment. It can be very distracting. I have another video of a couple "incident's" at this summer's Sports Class Nationals that were far, far, FAR worse. Ill may put those up at some point in the future. How would the rules committee govern this? How can this be enforced, if it is improper technique or unsafe according to the standards the rules committee has set? What are the consequences for unsafe flying and how does one prove that they have been subjected to an unsafe pilots poor technique (or worse)? Seems like the onus is, unfortunately on me. Seems like the wild west at times. I see no disciplinary action happen to pilots who cause, for example, collisions. My goal is to better understand where the line is drawn and what I should expect and not expect.
Your description of entry technique describes best practices commonly taught even in basic training. I've reviewed this topic probably 10 times in safety talks in the last few years. It is the obligation of the entering pilot to not hinder the established pilot. It is not a rule, but very well established good practice for safety and courtesy.
Obviously there is no rule related to bumping a thermal and continuing. The pilot bumping has the same obligation to not affect the other pilot as the one entering.
How do you handle a situation after the fact?
1- Talk to the other pilot and find out if he or she saw you. Explain to them that the close proximity situation they created made you feel unsafe. The proper response from that pilot should be to accept your concern and agree to try not to repeat it.
2- Use the "safety box". This brings your concern to the attention of the contest organizers. A pattern of complaints about an individual will result in discussion with the offending pilot. Note some CD's, myself being one of those, would prefer to hear directly from the concerned pilot so they can better understand what occured.
3- There is disciplinary action for pilots involved in mid air collisions. For them, the flight end right there- mostly to encourage the decision to land promptly and safely. Damage to the glider usually can be expected to serve as any required additional punishment.
The goal is for all of us to act in a sportsmanlike manner so we can all enjoy our sport.
Nice video and a good discussion point. Expect to be asked to discuss this topic at an upcoming safety talk.
UH
Old October 31st 12, 02:51 PM posted to rec.aviation.soaring
shkdriver shkdriver is offline
Member
First recorded activity by AviationBanter: Aug 2008
Video here ---https://vimeo.com/52396659Side note: Interesting PowerFLARM warning in at the 9:13 point of this video. The glider that bumped directly thru this thermal (about 20 ft. below me) will go unnamed. I am not claiming he/she did anything wrong at this point. But...this happens often to me OFTEN in contests. My understanding is that contest pilots should not fly directly at another glider established in a thermal and should NOT do their pull-up at such close proximity. I had to change my direction significantly to stay in a position that I considered safe. My understanding is that a contest pilot MUST do their pull-up outside the thermal and blend in safely from the side of the thermal in a safe, predicable and benign manner. This is rarely the case in my experience. The glider in the thermal should have, for lack of a better work, the RIGHT OF WAY. But many, many do the straight in attack run technique in the contest environment. It can be very distracting. I have another video of a couple "incident's" at this summer's Sports Class Nationals that were far, far, FAR worse. Ill may put those up at some point in the future. How would the rules committee govern this? How can this be enforced, if it is improper technique or unsafe according to the standards the rules committee has set? What are the consequences for unsafe flying and how does one prove that they have been subjected to an unsafe pilots poor technique (or worse)? Seems like the onus is, unfortunately on me. Seems like the wild west at times. I see no disciplinary action happen to pilots who cause, for example, collisions. My goal is to better understand where the line is drawn and what I should expect and not expect.
3- There is disciplinary action for pilots involved in mid air collisions.. For them, the flight end right there- mostly to encourage the decision to land promptly and safely. Damage to the glider usually can be expected to serve as any required additional punishment.
UH
Great video, thanks for sharing it!
I would guess that pilot never saw you, and if he did, that would be
about the most dangerous act of piloting imaginable!
Thanks again for the video!
Scott W.
Old October 31st 12, 04:10 PM posted to rec.aviation.soaring
John Cochrane[_3_]
UH
This did look close. Moreover, his path seems to go straight through
your circle rather than join on the perimeter. It is likely the other
pilot did not see you.
I'm surprised to hear of more incidents at sports. In my experience
this is pretty rare.
Two more cents: It is worth reviewing the traces of such incidents.
Often the exact paths of the gliders are surprisingly different than
what we recall.
John Cochrane
Old October 31st 12, 05:21 PM posted to rec.aviation.soaring
kirk.stant
On Tuesday, October 30, 2012 4:10:58 PM UTC-4, Sean F (F2) wrote: Interesting PowerFLARM warning in at the 9:13 point of this video. The glider that bumped directly thru this thermal (about 20 ft. below me)...
Note that PowerFLARM did not give a collision warning (the display with dots for clock position and high/level/low indication). It warned of the presence of the converging glider, and gave direction/range/altitude info to facilitate visual pickup.
If you had missed the warning, and continued to turn, the other glider would most likely not have hit you (he was lower) and probably would have seen you as you showed your planform to him. Unless he was heads down reprogramming his task...
Excellent video - I hope a lot of non-believers see it!
Kirk
66
Old October 31st 12, 05:26 PM posted to rec.aviation.soaring
Jim White[_3_]
Sean, I guess you would get even more sympathy from other competition
pilots if you removed your cameras and spent more effort on flying safely
and lookout.
The massive amount of stuff you have stuck around your panel obscures your
view ahead, you rarely look out properly before making turns and levelling
out, and you seem to have a habit of flying thermals in the other pilots'
blind spot.
The problem with filming your flights (as I have done, and no longer do) is
that others are able to tell how well or badly you fly! The lesson I
learned from the exercise was to work harder on my lookout.
Did you see the other aircraft before it flarmed you? You had not looked in
that direction for a turn. As the other aircraft set off flarm, then he
would probably have been alerted to you even if he hadn't seen you at that
point. I doubt you were in great danger from the other pilot.
Old October 31st 12, 07:34 PM posted to rec.aviation.soaring
Martin Smith[_2_]
In addition to all the things that UH said, in UK contests we typically
have a pilot safety committee. This is 3 competitors deemed to be respected
and experienced, often senior instructors, and approved by a simple show of
hands at the beginning of the contest. Any issue like this can be brought
to their attention and the matter of genuine mistakes or safety concerns
can generally be resolved by chat and peer review. Normally a quiet, "mind
how you both go," works wonders all round and everybody learns from the
experience. Anything that turns out to be really bad can be escalated to
the comp organisers for possible penalty or official warning etc.
Personally I dislike folks barreling in to an established thermal and
causing me to take some precautionary action as you chose to do. As Jim
says, the other guy's flarm would have warned him about you and I think he
could have made a bit more effort on this occasion.
Martin N5
Old October 31st 12, 09:26 PM posted to rec.aviation.soaring
John Cochrane[_3_]
Note that PowerFLARM did not give a collision warning (the display with dots for clock position and high/level/low indication). *It warned of the presence of the converging glider, and gave direction/range/altitude info to facilitate visual pickup.
If I understand things correctly, this means that in "stealth" mode,
neither of the two gliders would have had any indication of the
other's presence by flarm. An interesting observation for the parallel
flarm leeching thread
John Cochrane
Old October 31st 12, 11:14 PM posted to rec.aviation.soaring
On Wednesday, October 31, 2012 5:26:26 PM UTC-4, John Cochrane wrote:
Note that PowerFLARM did not give a collision warning (the display with dots for clock position and high/level/low indication). *It warned of the presence of the converging glider, and gave direction/range/altitude info to facilitate visual pickup. If I understand things correctly, this means that in "stealth" mode, neither of the two gliders would have had any indication of the other's presence by flarm. An interesting observation for the parallel flarm leeching thread John Cochrane
Or maybe Flarm did not compute a collision solution and thus did not warn.
Repeating for the who knows how many'th time - Steath does not suppress collision warnings.
Sigh
UH
Old November 1st 12, 12:57 AM posted to rec.aviation.soaring
Sean F (F2)
Thanks! Appreciate the response. I think we need to add even more emphasis to this as not to scare new pilots. :-)
2012 Region 4 North Fairfield - Last chance to race in 2012! Team flying! Auxvache Soaring 1 August 24th 12 11:10 PM
ASW-20 for Region 6 North 2012 hotelalpha Soaring 4 December 29th 11 01:43 PM
Region 3 contestants Welcome-Region Six North Contest Ionia November Bravo Soaring 0 August 13th 09 12:53 PM
Region 4 North user Soaring 0 September 6th 07 01:24 AM
REgion 6 North is on..... Robert Hills Soaring 0 July 15th 04 03:08 PM
