Gelcoat Spraying Equipment
Old November 3rd 12, 01:08 AM posted to rec.aviation.soaring
Terry Edmonds
Default Gelcoat Spraying Equipment
I am repairing a small gelcoat scratch and looking for recommendations on a small gelcoat sprayer . Wondering if liquid gelcoat is to viscous for an airbrush to work?
Old November 3rd 12, 01:38 AM posted to rec.aviation.soaring
Craig Funston[_2_]
You can thin gelcoat with either acetone or lacquer thinner. Lacquer thinner tends to work better since it flashes slower and doesn't tend to orange peel as much. Thin the material until it sprays well. Probably about the consistency of 2% milk. Start with a very light fog coat and let that gel a bit before putting on a full coat. This will help keep the paint from running off the prepped surface.
Small scratches also respond well to brushing since you'll have to block out the repair and polish it anyways. Often you can limit the extent of collateral damage by just grooving out the scratch and filling it with gelcoat. Far less messier than spraying.
Good luck,
Craig
Gel Coat Spraying Equipment Terry Edmonds Soaring 9 November 13th 12 08:30 PM
Spraying enamel Michael Horowitz Home Built 0 July 22nd 10 07:37 PM
Gelcoat sag? [email protected] Soaring 10 December 17th 07 08:07 PM
Start of Ag Spraying Season Ol Shy & Bashful Rotorcraft 4 June 15th 06 05:18 AM
gun for spraying primer Mike Rapoport Home Built 6 September 6th 05 03:35 PM
