Drunk pilot loses certificate
Old January 26th 04, 08:06 PM
C J Campbell
Default Drunk pilot loses certificate
According to AVweb, John V. Salamone was the drunk pilot who flew through
controlled airspace near Philadelphia on Jan. 15. The FAA alleged that the
pilot endangered the lives of others and forced diversions of several
airliners. His breathalyzer was .13 alcohol level. The FAA has revoked his
certificate.
Apparently this guy was a solid citizen who had never done anything like
this before. Makes you wonder what happened to him.
Christopher J. Campbell
World Famous Flight Instructor
Port Orchard, WA
If you go around beating the Bush, don't complain if you rile the animals.
Old January 26th 04, 08:18 PM
Peter R.
C J Campbell ) wrote:
snip
I believe you meant to type that he was a citizen who never got *caught*
before. Who here can say whether this individual has ever flown under the
influence prior to this incident?
IMO, I hope he never gets his certificate back.
Peter
Old January 27th 04, 03:42 AM
Travis Marlatte
Hmm. No wonder I don't watch the news. Either this guy was a solid, stand-up
citizen who has made one mistake in his life OR he is a drunk, has been a
drunk, always will be a drunk.
I'm guessing that I don't really know who he is or what really happened. I'm
also guessing that I never really will. I just hope that the FAA treats him
fairly, that he resolves whatever personal or physical issues he may have,
and that, someday, he gets to fly again.
But that's just my opinion!
Travis
"Peter R." wrote in message
snip
Peter
News==----
Newsgroups
Old January 27th 04, 05:38 AM
Tom Sixkiller
"Travis Marlatte" wrote in message
link.net...
stand-up
More likely the latter.
I'm
him
Doesn't matter who he is; what matters is that he endangered hundreds of
people with a stunt that would make a teenager blush.
Old January 27th 04, 06:46 PM
Big John
Tom
Hate to drop a brick on your foot, especially if you have it in your
mouth for being so equivocal.
I've see a number of individuals who drank from wake up to the time
their eyes closed for sleep at night.
They were able to pass any and all tests of ANY kind (memory, verbal,
body activity, etc) given to them other than a breathalizer (sp) which
only measures a approximation of alcohol in the body, not any
impairment. The powers that be, assume impairment with an arbitrary
level measured.
How do you know this individual was not one whose body assimilated
alcohol in a manner that did not effect normal activities by any
measure (test)? Were the results of any impairment tests published?
One last shot over the bow. How many stone cold sober individuals have
flown through controlled airspace (the alleged activity)? Were their
ticket revoked?
Big John
On Mon, 26 Jan 2004 22:38:25 -0700, "Tom Sixkiller"
hlink.net...
stand-up
I'm
him
Old January 27th 04, 06:54 PM
Tony Cox
"Big John" wrote in message
Presumably because he was repeatedly busting class B and
causing other traffic to divert.
Old January 27th 04, 08:42 PM
James Robinson
level measured.
The tolerance of long-term users of alcohol is somewhat of a myth.
Alcoholics certainly are able to appear to "hold" their liquor by not
having the same loss of motor skills and reaction times as casual users,
but those measures are not the complete story. Alcohol affects many
things, such as depth perception, night vision, the ability to do
multitasking, judgment, concentration, and so on. Many of these more
complex, but less obvious abilities are affected by the same amount
whether or not the person has gained a tolerance for alcohol. There are
precisely the skills that are necessary for safe flight.
Long term alcohol use does create a tolerance, which manifests itself
mostly in the area of motor skills. It takes a higher blood alcohol
content for an alcoholic to reach the same level of "impairment' as a
casual drinker, as measured by motor skill and reaction time testing.
However, while motor skills might be less affected, most research
suggests that alcohol equally affects those with an alcohol tolerance
and those without. Judgment and the ability to do several things at the
same time are prominent on those lists.
Alcoholics are the most dangerous, since they think they are not
affected, and other people don't notice the effects as quickly. However,
they do have many of the same physical reactions to alcohol,
particularly those which are critical to safety. These can include a
lowered ability to judge distances, to track other objects and determine
points of path intersection, some loss of night vision, and reduced
ability to absorb external information.
In particular, testing has been performed on simulators, and it has been
found that while a pilot with a tolerance for alcohol might be able to
fly a routine flight with an elevated blood alcohol level with no
noticeable problems, things change when his workload increases. The
alcoholic pilot tends to concentrate on the mechanics of flying to the
exclusion of all else, just as much as a casual drinker. This results
in a tendency to overcontrol, lapses in judgment, and a tendency to
block out more and more external information, such as inputs from
peripheral vision, radio communications, non-essential gauges, and so
on. In short, they focus, and lose the ability to absorb and evaluate
information. Imagine what happens in IMC with a partial panel failure,
or a fuel problem while trying to stabilize for landing.
Because alcohol has similar effects on all people for the more complex
tasks, the impairment levels are not arbitrary, and long term alcohol
use does not give people immunity from its effects.
Old January 28th 04, 12:08 AM
Maule Driver
"Big John"
ticket revoked?
There is a tendency irrationally condemn intoxicated people. But in this
case, the pilot was objectively intoxicated and he clearly acted in a
reckless and careless manner. Whether he was sober or drunk while doing
what he did, it would seem to justify pulling the ticket. The alcohol is a
reasonable explanation for the bizarre behaviour. Without the alcohol, the
guy needs medical help,
Old January 30th 04, 08:38 AM
Happy Dog
What do you mean by "drank"? What BAC are we talking about? Seasoned
drinkers can mask the symptoms of imparment to an extent. But above .15,
it's nearly impossible.
No need. Impairment by any intoxicating substance is just too dangerous to
sanction. Or do you suggest that only certain types of flying be allowed
when impaired?
le moo
Old February 1st 04, 09:06 AM
Big Dave
Big John wrote:
Tom
You frequently defend pilots who habitually drink to excess. I would
not be surprised to find that you are a chronic alcoholic. Of course,
you'll deny everything here but that is neither here nor there. Most
alcoholics are in extreme denial anyway. As one with three alcoholics
in the family, one a retired airline pilot (my father), one dead (my
mother), and my brother being the third, your words and attitude are
all too familiar.
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 02:54 AM
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Piloting 25 September 11th 03 01:27 PM
Enlisted pilots John Randolph Naval Aviation 41 July 21st 03 02:11 PM
