GPS question
Old January 27th 04, 05:26 PM
Ingo K?hne
Default GPS question
Hello
I am not a real pilot, just interested in aviation and simulation. My
question is if the GPS with all its accuracy and worldwide
availability will soon replace all other navaids for IFR. So a little
provocative: who needs VORs and NDBs anymore?
Old January 27th 04, 07:42 PM
DeltaDeltaDelta
as far as i have heard from some ATC sources i have, the NDBs will be the
first to go and the ones least used (leats critical) are already shut down.
Omega was also turned off recenlty i heard. Then VORs will go until nothing
is left except satellites...but that won't happen for some years still
(depending on the part of the world) till all aircraft become standard
equipped with GPS gear.
Triple Delta
"Don Tuite" wrote in message
On 27 Jan 2004 09:26:25 -0800, (Ingo K?hne)
Hello
They'll be decomissioned when we run out of spares.
Don
Old January 27th 04, 10:30 PM
Roger Hamlett
"Ingo K?hne" wrote in message
m...
Hello
It'll happen when there is a second fully operational GPS system in place.
This is part of the reason why the EU, are moving into launching their own
constellation. Since these will use a seperate frequency, it gets away from
the possibility of a single source jamming all the systems in use
(accidentally), or a single hardware failure removing the only navigational
source.
Best Wishes
Old January 28th 04, 01:54 AM
Ron Lee
Ground-based navaids will be here for our lifetimes. Check out the
latest Federal Radionavigation Plan
http://www.navcen.uscg.gov/pubs/frp2001/default.htm
Ron Lee
Old January 28th 04, 04:44 AM
Jürgen Exner
You cannot solely rely on a single navigation aid system, in particular if
it is controlled by the military.
Therefore there will always be some form of terrestial navigation aid as a
backup system.
jue
Old January 28th 04, 07:07 AM
Brian Burger
You cannot solely rely on a single navigation aid system, in particular i=
f
Add to that that for non-Americans, GPS is controlled by a *foreign*
military. Decommisioning surface nav in favour of foreign-controlled GPS
is not something even friendly governments will do lightly. Hence the EU's
proposed (in progress?) parallel GPS network, as well.
The other major reason is that there are lots and lots of older aircraft
(private and commercial) that still rely on the surface nav for their
primary or only navigation insturments. Aviation GPS is not a cheap
upgrade for older but still servicable planes...
Brian.
Old January 28th 04, 10:01 AM
Thomas Borchert
Ingo,
well, for one thing, GPS as deployed now, even with WAAS, is not
accurate enough for precision approaches, e.g. ILS replacement.
Thomas Borchert (EDDH)
Old January 31st 04, 09:06 PM
Ron Lee
backup system.
jue
You might look to see how many countries have approved IFR navigation
using GPS. The use of "military controlled" is one of those
xenophobic phrases used to justify Galileo. I use GPS frequently and
I have ZERO concerns about the people who operate the system.
Ron Lee
American and proud of it
Speech: A Question of Loyalty: Gen. Billy Mitchell Otis Willie Military Aviation 0 September 25th 04 09:30 PM
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
Legal question - Pilot liability and possible involvement with a crime John Piloting 5 November 20th 03 09:40 PM
