New Class for US Nationals
Old November 7th 12, 07:21 PM posted to rec.aviation.soaring
Default New Class for US Nationals
The US Rules Subcommittee has added Club Class as a national championship class starting in 2013. The plan is to co locate with Sports.
Generally described, subject to usual wordsmithing and refinement, Club will be gliders with a handicap of .898(similar to what Worlds does except letting in LS-6 and Ventus 1) and all lower performance gliders. This means we extend beyond what WGC does on the low end to let everybody be able to play. No water ballast will be used.
"Modern" Sports will allow anybody to be in this class but handicap limit will be .940. Gliders below that performance may enter but will not receive the full handicap benefit and tasking considerations will not reflect their performance. No water ballast will be used.
This concept allows common std ships like Discus etc and ships like 20's to decide which class they would like to enter.
The rules will provide for assigned tasks in both Modern Sports and Club, subject to task setter evaluation of the fleet in the class.
If we do not get 12 in Club and Modern Sports, the contest reverts to traditional Sports only.
Final numbers and rules text will be a few weeks away using the normal rules process.
Final approval will be at the SSA BOD winter meeting in February.
It is expected that the US Team committee will use Club results going forward to select the Club team. This has not yet been confirmed by the USTC.
We are making this announcement in advance to allow affected pilots more time to plan.
If we waited through the full process, it would be only 3 months from approval to the race.
Full details of the proposed rules will be available as part of the Rules Change Summary due to be published on 12/22/12.
This will require re doing entries after the rule becomes effective. Thanks to Karl and Iris for putting up with this extra work. It would be helpful to them if you advise what class you intend to fly in.
For the Rules Committee
UH
RC Chair
Old November 8th 12, 05:08 AM posted to rec.aviation.soaring
wallace berry
Sports.
rules process.
the USTC.
more time to plan.
UH
RC Chair
Excellent! Many thanks to the Rules Committee!
wb
--- news://freenews.netfront.net/ - complaints: ---
Old November 8th 12, 05:19 AM posted to rec.aviation.soaring
RW[_2_]
UH
RC Chair
I'm very disappointed with RC .
Club Class has to have only IGC Club Class gliders : no LS-6 and no Ventus pls.
Weight of the Club Class glider should be like by IGC : gross less water in the wings(tail water for balance OK)
Handicap should not change,like IGC ,if pilot elects to fly with lower weight (no extra points for small pilots)
Our US Club Class has to be like IGC Club Class.
Our primary goal will be winning of WGC
RW ( Ryszard Krolikowski)
Old November 8th 12, 01:45 PM posted to rec.aviation.soaring
On Thursday, November 8, 2012 12:19:01 AM UTC-5, RW wrote:
On Wednesday, November 7, 2012 2:21:57 PM UTC-5, wrote: The US Rules Subcommittee has added Club Class as a national championship class starting in 2013. The plan is to co locate with Sports. Generally described, subject to usual wordsmithing and refinement, Club will be gliders with a handicap of .898(similar to what Worlds does except letting in LS-6 and Ventus 1) and all lower performance gliders. This means we extend beyond what WGC does on the low end to let everybody be able to play. No water ballast will be used. "Modern" Sports will allow anybody to be in this class but handicap limit will be .940. Gliders below that performance may enter but will not receive the full handicap benefit and tasking considerations will not reflect their performance. No water ballast will be used. This concept allows common std ships like Discus etc and ships like 20's to decide which class they would like to enter. The rules will provide for assigned tasks in both Modern Sports and Club, subject to task setter evaluation of the fleet in the class. If we do not get 12 in Club and Modern Sports, the contest reverts to traditional Sports only. Final numbers and rules text will be a few weeks away using the normal rules process. Final approval will be at the SSA BOD winter meeting in February. It is expected that the US Team committee will use Club results going forward to select the Club team. This has not yet been confirmed by the USTC. We are making this announcement in advance to allow affected pilots more time to plan. If we waited through the full process, it would be only 3 months from approval to the race. Full details of the proposed rules will be available as part of the Rules Change Summary due to be published on 12/22/12. This will require re doing entries after the rule becomes effective. Thanks to Karl and Iris for putting up with this extra work.. It would be helpful to them if you advise what class you intend to fly in.. For the Rules Committee UH RC Chair I'm very disappointed with RC . Club Class has to have only IGC Club Class gliders : no LS-6 and no Ventus pls. Weight of the Club Class glider should be like by IGC : gross less water in the wings(tail water for balance OK) Handicap should not change,like IGC ,if pilot elects to fly with lower weight (no extra points for small pilots) Our US Club Class has to be like IGC Club Class. Our primary goal will be winning of WGC RW ( Ryszard Krolikowski)
I would have been shocked if you weren't dissapointed.
We expect that weights will be handled as we do now with Sports as this is what we see as most fair to all.
We included LS-6 and Ventus because they are contemporary with the ASW-20 which is on the IGC list.
Our Club class does not have to be exactly like IGC Club class.
Finally- our primary goal is participation, especially among new talented pilots with limited means, with winning of the WGC as a secondary concern.
UH
Old November 9th 12, 04:10 PM posted to rec.aviation.soaring
RW[_2_]
On Wednesday, November 7, 2012 2:21:57 PM UTC-5, wrote: The US Rules Subcommittee has added Club Class as a national championship class starting in 2013. The plan is to co locate with Sports. Generally described, subject to usual wordsmithing and refinement, Club will be gliders with a handicap of .898(similar to what Worlds does except letting in LS-6 and Ventus 1) and all lower performance gliders. This means we extend beyond what WGC does on the low end to let everybody be able to play.. No water ballast will be used. "Modern" Sports will allow anybody to be in this class but handicap limit will be .940. Gliders below that performance may enter but will not receive the full handicap benefit and tasking considerations will not reflect their performance. No water ballast will be used. This concept allows common std ships like Discus etc and ships like 20's to decide which class they would like to enter. The rules will provide for assigned tasks in both Modern Sports and Club, subject to task setter evaluation of the fleet in the class. If we do not get 12 in Club and Modern Sports, the contest reverts to traditional Sports only. Final numbers and rules text will be a few weeks away using the normal rules process. Final approval will be at the SSA BOD winter meeting in February. It is expected that the US Team committee will use Club results going forward to select the Club team. This has not yet been confirmed by the USTC. We are making this announcement in advance to allow affected pilots more time to plan. If we waited through the full process, it would be only 3 months from approval to the race. Full details of the proposed rules will be available as part of the Rules Change Summary due to be published on 12/22/12. This will require re doing entries after the rule becomes effective. Thanks to Karl and Iris for putting up with this extra work. It would be helpful to them if you advise what class you intend to fly in. For the Rules Committee UH RC Chair I'm very disappointed with RC . Club Class has to have only IGC Club Class gliders : no LS-6 and no Ventus pls. Weight of the Club Class glider should be like by IGC : gross less water in the wings(tail water for balance OK) Handicap should not change,like IGC ,if pilot elects to fly with lower weight (no extra points for small pilots) Our US Club Class has to be like IGC Club Class. Our primary goal will be winning of WGC RW ( Ryszard Krolikowski)
UH
After 98% of racing pilots voted for club class gliders drivers to be considered for US Team, we had 2 years of waiting period before this could be implemented .
Meantime RC quietly expands list to LS-6 and this year quietly to
Ventus.(without asking anybody,without waiting period)
It is very disappointing that RC member showed up in Parowan Sports Nationals
with Ventus as a big surprise of new extended club class list !
RW
Old November 9th 12, 04:42 PM posted to rec.aviation.soaring
John Cochrane[_3_]
RW: you're setting new standards of incoherence here
98%? I'd like to see that poll. I write the poll and read the results
annually. We haven't had 98% on the proposition "should the sky remain
blue?"
I presume you mean Garrett Willat in a Ventus ca. Then, you're only
getting wrong that Garrett isn't a RC member, the rule we're talking
about apply starting this year, not retroactive to last year, the
Ventus ca he flew was already on the US club class list (there is a
big "C" next to the glider on the ssa handicap table) and the fact
that the US team, not the rules committee decides which entrants from
a unified sports class qualify for US team club class points.
Maybe you mean Ken Sorenson (ssa contest committee chairman) in a
Ventus 2. Then you're getting wrong the difference between ventus 1
and ventus 2.
No other RC members competed at Parowan. With great regret, but in
fact we weren't there.
If you're mad that Garret beat you, on a handicapped basis, maybe
trying to engineer a contest where he doesn't get to come isn't the
answer.
A big theme of US team self-analysis right now is that we fly in races
that are too small. Europeans don't just fly in particular classes
with particular rules. They fly in huge contests with many top level
contenders, not just one or two. The case that we get better by
sending half the fleet home, eliminating lower-performance gliders
from nationals altogether, and having a little toy contest with 8.0
gliders seems pretty tenuous. If you want to get pushed to WGC level
performance, you should be offering to pay Garret's entry fee so that
a talented pilot with WGC experience will push up the level of
competition. No matter what glider he is in.
We gave you a contest with no ASW27/ASG29s, no Ventus 2s, no open
class gliders, no duos, and none of the FAI pilots who typically fly
those gliders and aren't about to waste their two weeks of vacation
flying the club standard cirrus at Mifflin.
Your job is to make darn sure 12 pilots in even our expansive
definition of club class show up. If they do not, the whole project is
over. Are you listening? The future of club class depends on getting a
sufficient turn out.
As the stones sang,
No, you can't always get what you want
But if you try sometime, you just might find
You get what you need
John Cochrane
Old November 9th 12, 11:24 PM posted to rec.aviation.soaring
Papa3[_2_]
I apply a very simple test on any rule. If RW's not happy, then it's a good rule.
P3
Old November 10th 12, 03:30 PM posted to rec.aviation.soaring
RW[_2_]
blue?"
I believe it was 2006 racing pilots pool !
After majority of pilots(is this better for you John,or maybe 97%,why exact number is soo important ?)voted for "only club class glider pilots" to be considered for US Team.
John, you are just angry.
RC asked this question and in following years deviated from it quietly, against majority of racing pilots wish.
If this was your decision, I would like you to step down.
I'm sick of your reinventing wheel and continuous changing rules, also treading experience racing pilots as kids.
RW
Old November 9th 12, 04:43 PM posted to rec.aviation.soaring
Kevin Christner
And the Ventus and LS6 will have a significant advantage at this years Mifflin Nationals if their are a few ridge days. I also wonder if you will ever get enough "modern" gliders to have two classes if the Ventus and LS6 are considered "club" gliders.
RW
Old November 9th 12, 04:58 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
On Nov 9, 11:43*am, Kevin Christner wrote:
And the Ventus and LS6 will have a significant advantage at this years Mifflin Nationals if their are a few ridge days. *I also wonder if you will ever get enough "modern" gliders to have two classes if the Ventus and LS6 are considered "club" gliders.
Given the handicaps, I'll keep my 20, thanks.
A well flown Ka-8 will kill all the glass on a ridge day. Ron
Schwartz in a 1-26 will eat the Ka-8 and spit out the wing pins,
provided he can make the transitions.
-Evan Ludeman / T8
Day 3 at U.S. Sports Class Nationals Frank Paynter[_2_] Soaring 2 May 8th 11 12:50 AM
Sports Class Nationals John Godfrey (QT)[_2_] Soaring 0 June 25th 10 02:56 PM
Location of 2006 US 18m nationals and Sports Class Nationals and 15m ? John Bojack Soaring 2 July 18th 05 02:45 PM
US Standard Class and World Class Nationals at Hobbs Ken Sorenson Soaring 7 July 16th 04 04:03 AM
UK Open Class and Club Class Nationals - Lasham Steve Dutton Soaring 0 August 6th 03 10:07 PM
