blanik cracks
Old November 8th 12, 09:02 PM
hangtruck hangtruck is offline
Junior Member
First recorded activity by AviationBanter: Nov 2012
Default blanik cracks
One of our super blaniks has a crack in the bottom forward vertical stabilizer panel. I've looked the at the diagrams and inspected it from inside and I only think It's for aerodynamic and appearence purposes. On single engine recip Pipers it's made of plastic. I am having a hard time coming up with information on this and need to know what I'm dealing with.
Old November 9th 12, 06:32 AM posted to rec.aviation.soaring
aerodyne
On Nov 8, 1:02*pm, hangtruck
with.
hangtruck
You should have a service and repair manual. If not, you can ask
Blanik America for a copy. The Blanik manuals tend to be extremely
detailed and well written
If the panel is made of royalite or ABS plastic, and held on with
widely spaced screws then you may assume it is non structural and
repair/replace it as a non structural fairing per part 43. Even non
structural parts need repair!
I don't recall the part in question, but I doubt if it is anything
like the Piper example you mention. Even if it is, then by definition
it should not be taking load. There is a forward drag spar per a 3
view I saw, it is possible you have internal damage in that area.
aerodyne
Old November 9th 12, 09:09 PM
Junior Member
with.
hangtruck
aerodyne
have the manuals,they are what you say. Obviously then the right thing to is call Blanik. Thanks.
Cracks are bad news, right? JJ Sinclair[_2_] Soaring 14 July 4th 12 11:34 PM
Gel Coat Cracks or is it worse? [email protected] Soaring 13 June 30th 12 09:41 PM
Blanik L-23 Super Blanik Manual -F.C.F.S. Joel Flamenbaum Soaring 2 April 14th 10 03:29 PM
Jim Payne Cracks 1,072 Miles! [email protected] Soaring 3 March 28th 08 10:32 PM
RV-4 Cracks guynoir Home Built 3 May 29th 04 07:29 AM
