Tow Pilot Checkouts, Rough-Field Tri-Gears?
Old November 13th 12, 12:28 AM posted to rec.aviation.soaring
noel.wade
Default Tow Pilot Checkouts, Rough-Field Tri-Gears?
All -
Do any of the USA folks here on RAS operate in a club without a 2-seat
towplane? If so, how do you check out new towpilots? Do you find
simulated towing acceptable training?
On a related topic: Given the dearth of Robins in the USA for tri-gear
towing, does anyone have suggestions on a tri-gear towplane that can
operate out of a rough grass strip? We now land on asphalt, but our
takeoff area has some broad swales and occasional mole-holes. It has
spawned legends of bent Cessna firewalls; so a 180 or 182 seems to be
out of the running. Any alternatives out there that are capable of
hauling up a loaded 2-seater like a G-103 or L-23?
--Noel
Old November 13th 12, 01:00 AM posted to rec.aviation.soaring
Tim Taylor
On Nov 12, 5:28*pm, "noel.wade" wrote:
All -
towplane? *If so, how do you check out new towpilots? *Do you find
operate out of a rough grass strip? *We now land on asphalt, but our
takeoff area has some broad swales and occasional mole-holes. *It has
out of the running. *Any alternatives out there that are capable of
--Noel
Socata Rallye, one for sale here in Logan I think.
Old November 13th 12, 02:02 AM posted to rec.aviation.soaring
Paul T[_4_]
At 01:00 13 November 2012, Tim Taylor wrote:
On Nov 12, 5:28=A0pm, "noel.wade" wrote:
All -
towplane? =A0If so, how do you check out new towpilots? =A0Do you find
operate out of a rough grass strip? =A0We now land on asphalt, but our
takeoff area has some broad swales and occasional mole-holes. =A0It has
out of the running. =A0Any alternatives out there that are capable of
--Noel
Varga Kachina, Maule?
Old November 13th 12, 02:15 AM posted to rec.aviation.soaring
T[_2_]
On Nov 12, 4:28*pm, "noel.wade" wrote:
All -
--Noel
Any airplane is going to have problems with runways with mole holes,
you can drop a main tire into the hole as easily as nose wheels or
tail wheels.
A C180 is a taildragger, a C182 a nose dragger. So why is the 180 out
of the running?
We have a single seat Pawnee for towing, best tow plane made, Piper
Pawnees. Simulated tow training works, we've used Super Cub,
Decathlon, and C170 for training. First three tow flights for the new
tow pilot, a CFIG is in the glider, first tow is normal, 2nd tow,
worst student you can be, moving all around and box wake and slack
line training. 3rd flight, pattern tow. Followed by critique and
question/answer session.
A good tow plane? Depending on where you are and density altitude
issues. C150 with 150HP or better. C182 if light weight, high DA
you'll not want full fuel. Super cub with 180HP. Scout.
T
Old November 13th 12, 07:47 PM posted to rec.aviation.soaring
One club I was in used a 180hp 150 with a 172 nose wheel. We operated off of pavement and the grass cross strip, as well as the grass along the edge of the paved runway. This is some ancient history, I vaguely remember that the nose wheel has some issues with shimmy, and there were some issues regarding the STC for a climb prop for that engine/airframe combo.
P9
Old November 14th 12, 05:20 AM posted to rec.aviation.soaring
noel.wade
On Nov 13, 6:19*pm, T wrote:
Any club trying to maintain more than one tow plane with only 600 tows
per year is going to have financial issues. A Super Cub is a high
capital investment. The concern of grounding for an AD for a single
type (2 Pawnees) is understandable, but the capital investment of the
second tow plane could be higher than the revenue lost while
completing the AD.
T
Thanks for the info on your simulated tow regimen! Can I ask which
club this is?
Our club consistently does ~1300 tows per year. We never seem to use
our towplanes evenly; often the "nicest" Pawnee gets 700-800 tows per
year while the remaining 550-650 are split between the other two
planes (effectively at a loss). My analysis of our club finances
shows that 1300 tows is sufficient to support 2 towplanes as long as
you use them equally (i.e. about 650 tows per plane); but definitely
not 3 towplanes. Just as you've noted, doing less than about 600 tows
per towplane just doesn't make economic sense (the fixed costs are way
too high on a per-tow basis, you'd end up having to charge something
like $65+ for a 3000' tow just to keep up with yearly costs - and at
that rate you're not saving any money for long-term items like
engines, paint, fabric, etc).
--Noel
Gear Up, pt 7 - pilot Howard Hughes in a ploughed field.jpg (1/1) Mitchell Holman Aviation Photos 0 April 20th 07 02:21 PM
Rough Field Landings [email protected] Piloting 38 December 19th 04 01:42 PM
PIREP: 2I3 (Rough River State Park, Falls of Rough, KY) Kyler Laird General Aviation 0 March 1st 04 12:11 AM
J-3 Checkouts/vacations Dave Owning 9 August 14th 03 10:32 PM
J-3 Checkouts/vacations Dave Owning 4 August 11th 03 02:07 AM
