I've got an old screw pitch gauge that I inherited. There's no mfr's
name marked on it, just "Number 137". the individual leaves are marked with two numbers each, but these numbers are not reciprocals. The first number is always a small integer which I presume is threads-per-inch. the second number is always a decimal. All the leaves are of equal thickness, so they are not thickness calibrations as in a feeler gauge. Any idea what the second set of numbers are? |
Probably metric (in millimeters pitch)
Don "Alan Horowitz" wrote in message om... I've got an old screw pitch gauge that I inherited. There's no mfr's name marked on it, just "Number 137". the individual leaves are marked with two numbers each, but these numbers are not reciprocals. The first number is always a small integer which I presume is threads-per-inch. the second number is always a decimal. All the leaves are of equal thickness, so they are not thickness calibrations as in a feeler gauge. Any idea what the second set of numbers are? |
Carb Temperature Gauge | fly_the_skies | Home Built | 6 | January 14th 04 03:32 PM |
Bothersome Phillips Head Screws | Larry Smith | Home Built | 48 | January 10th 04 04:26 AM |
Pitch and Diameter of 3 blade prop for IO-360 200HP | Bart D. Hull | Home Built | 1 | December 11th 03 11:42 PM |
ALTRAK pitch system flight report | optics student | Home Built | 2 | September 21st 03 11:49 PM |
