Lowering cockpit RF interference
Old December 14th 12, 07:04 PM posted to rec.aviation.soaring
Default Lowering cockpit RF interference
Hello all EEs.
What is standard operating procedure for when and where to use shielded wire in cockpit wiring?
What is standard operating procedure for when and where to use ferrite sleeves?
Do both the positive and negative lead need to pass through the ferrite sleeve?
Thanks for the education.
Old December 14th 12, 07:33 PM posted to rec.aviation.soaring
Tom Gardner[_2_]
Hello all EEs.
It can all be a bit trial and error, but
http://audiosystemsgroup.com/SAC0305Ferrites.pdf
gives some of the theory and practical aspects of it.
Key points:
- mount "close" to interference source
(close = less than 1/20th of the wavelength)
- mount "close" to whatever is being affected by
the interference
- multiple loops are better, usually
- resonance can cause surprises; be prepared to experiment
- any piece of wire can be an antenna, including the
cable shields
Old December 14th 12, 08:00 PM posted to rec.aviation.soaring
Richard[_9_]
On Friday, December 14, 2012 11:04:39 AM UTC-8, wrote:
Hello all EEs. What is standard operating procedure for when and where to use shielded wire in cockpit wiring? What is standard operating procedure for when and where to use ferrite sleeves? Do both the positive and negative lead need to pass through the ferrite sleeve? Thanks for the education.
What equipment do you have in the cockpit,specify all equipment, Make and Model?
What kind on interference are you getting?
Richard
www.craggyaero.com
Old December 14th 12, 10:15 PM posted to rec.aviation.soaring
Dave Nadler
http://www.zug.com/img/ThreadImg/A/8...?ts=1355523304
Old December 14th 12, 10:24 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
On 12/14/2012 11:04 AM, wrote:
Hello all EEs.
The simple answer: whenever the equipment installation manual tells you
to use it.
Typically use shielded wire for antenna cables (ie, coax) and microphone
cables.
Newer equipment usually comes with sleeves on the cables they supply.
If the equipment installations done properly, nothing additional is
needed in an unpowered glider. Powered gliders can have interference
generated by the engine running, but again, if the engine electrics are
installed properly and in good condition, there usually isn't a problem.
Generally, I'm amazed at what people can get away with doing!
Most electrical noise problems come from specific problems in the
installation, and can be tough to track down. Ferrites can be an easy
fix sometimes; shielded wiring isn't so easy to install, and it's often
hard for even an experienced EE or technician to know exactly which
cable(s) is the problem and should be replaced.
email me)
Old December 15th 12, 01:23 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
The only electrical noise problem I've had was when I installed a 28v T&B
which was powered of the glider's 12v supply with a solid state 12v-28v
DC-DC converter. The solution was to put an electrolytic capacitor across
the 12V supply to the converter. This was a specialized noise cancelling
capacitor and IIRC it is 150 uF with a 1.5A transient current capacity.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old December 15th 12, 06:49 PM posted to rec.aviation.soaring
Dan Marotta
I had the same problem, though with a 12v T&B, and used a ferrit in the
power lead to solve it.
org |
Old December 15th 12, 10:32 PM posted to rec.aviation.soaring
I think I tried a ferrite core on the 12v side of the voltage converter
without success and then remembered that Maplins (the UK equivalent of
RadioShack) had these capacitors at a reasonable price. Better yet it was
easy to fit: I just soldered it across the T&B power switch.
T&B which was powered of the glider's 12v supply with a solid state
12v-28v DC-DC converter. The solution was to put an electrolytic
capacitor across the 12V supply to the converter. This was a
specialized noise cancelling capacitor and IIRC it is 150 uF with a
org |
Old December 16th 12, 07:02 PM posted to rec.aviation.soaring
bumper[_4_]
org
A couple of thoughts here . . .
When you say you soldered it "across" the power switch, that might lead one to assume you soldered it to the two terminals of your switch, i.e. in parallel with the switch contacts). Normally a filter capacitor would be connected across the power leads, i.e. from + to -. While a filter inductor (such as a ferrite) is connected in series.
When trouble shooting RFI, it helps to be able to quantify results. If it's interferance on comm freqencies, a hand held radio can be useful - squelch off, and distance away from suspected RFI source as appropriate one can use the handheld as a field strength meter for radiated interferance.
This is not so much use when dealing with closely spaced instruments on the panel where one is causing problems with another (LNAV did that to Comm on one of previous glider). There, just slapping in clamp-ferrites did the job.
If you have enough slack in wiring leads, and the size of the ferrite allows, you get almost double the iductance for loopiing the wire/s through the ferrite twice, (or even more for 3 times etc). Sometimes adding a capacitor in concert with the ferrite helps even more, especially when noise is coupling via power leads (ferrite or inductor in series and cap across the wires in parallel to form a classic pi filter).
Ferrites are not all the same, they have a frequency band at which they will be most effective. Same thing with the size of capacitors used in filtering apps. (do a search on inductive and capacitive reactance and resonant frequecy). In the U.S., Digi-Key is one good source for ferrites etc.
bumper
zz
Minden, NV
bumper
Old December 16th 12, 08:06 PM posted to rec.aviation.soaring
The switch is a double pole push-on push-off type, so one pole each for
ground and 12v I was able to use it as a two position tag strip, which
made wiring easier. The capacitor is across the +12 and ground connectors
on the T&B side of the switch.
interferance.
It was purely electrical noise that cut in when the T&B was nearly up to
speed. I don't think it was RF because:
(a)ferrites didn't have any effect
(b) if it was coming from the DC-DC 12-28v solid state adapter I'd have
expected to hear it loudest when the T&B started because thats when you
see the biggest current drain from an electric motor.
(c) an old, mechanical T&B shouldn't be an RF source unless its sparking
like hell. This is a Mil-spec R C Allen type MD-4A, so possibly ex-USAF,
that has been modified to suit a glider's rate of turn rather than a
power plane. I'm told that these devices have a centrifugal switch that
sets the RPM and has the side effect of switching in and out at several
tens of cycles a second when its up to speed. That is what the racket
sounded like too.
did the job.
This was very easily localized: T&B off: no problem. T&B turned on: nasty
noise on the radio once it had spun up. No effect from turning any other
stuff on or off.
....other good stuff snipped.
org |
Trying again: Collings Foundation B-17 at Newcastle Airport inDelaware - B-17 cockpit.jpg - B-17 cockpit.jpg (1/5) Jim Breckenridge Aviation Photos 1 August 30th 08 07:36 PM
Trying again: Collings Foundation B-17 at Newcastle Airport in Delaware - B-17 cockpit.jpg - B-17 cockpit.jpg (0/5) Go-dot Aviation Photos 0 August 28th 08 11:39 PM
Wings of Freedom B-17 Wilmington, DE - B-17 cockpit.jpg - B-17 cockpit.jpg (0/5) Go-dot Aviation Photos 0 August 28th 08 09:37 PM
Retraction (lowering?) assist springs on V2C [email protected] Soaring 1 January 5th 06 05:20 PM
Lowering Stall Dick Home Built 7 December 25th 03 03:19 PM
