Looking for a formula to convert Kg/m2 to LB/FT2
Old December 15th 12, 12:51 AM posted to rec.aviation.soaring
Zen63T
Default Looking for a formula to convert Kg/m2 to LB/FT2
Is there a conversion short cut for changing 24.2 per square meter into pounds per square foot?
I believe 24.2 Kg/2M can be expressed as 4.95 Lb/2F. Does this seem reasonable?
Dale
Old December 15th 12, 12:59 AM posted to rec.aviation.soaring
Dave Nadler
https://www.google.com/search?q=conv...ient=firefox-a
http://www.onlineconversion.com/foru...1113415970.htm
Old December 15th 12, 01:38 AM posted to rec.aviation.soaring
Guess you have to Google the right wording - thanks a bunch.
Dale
Old December 15th 12, 07:01 PM posted to rec.aviation.soaring
Dan Marotta
Just in case nobody has yet suggested this program, try this - I use it all
the time.
http://joshmadison.com/convert-for-windows/
"Dave Nadler" wrote in message
Old December 15th 12, 07:09 PM posted to rec.aviation.soaring
JS
In this case divide by five works pretty well!
For multiple conversion types the download both Andy and Dan suggested is a very good tool.
Old December 15th 12, 07:45 PM posted to rec.aviation.soaring
I get a better visual using lb/ft2 but when I read about wing loading or when in Condor everything is express in Kg/m2. Divide by 5 is perfect for the use.
Thanks
Dale KA6CR Driver
Old December 15th 12, 01:12 AM posted to rec.aviation.soaring
Jock Proudfoot
Try- http://www.convertme.com/en/convert/...re/kgcmsq.html
reasonable?
Old December 15th 12, 01:22 AM posted to rec.aviation.soaring
Jock Proudfoot
reasonable?
Old December 15th 12, 10:42 AM posted to rec.aviation.soaring
Jim White[_3_]
reasonable?
Dale
divide by 5?
Old December 15th 12, 11:28 AM posted to rec.aviation.soaring
Tom Gardner[_2_]
http://www.google.co.uk/search?q=24....+sq uare+foot
How do I convert an instrument rating? tfitch03 General Aviation 0 October 27th 10 02:21 AM
convert turnpoints to KML for google earth? chris Soaring 4 January 15th 08 10:56 PM
Convert Cherokee 140 to 180? Tim Long Owning 24 January 11th 05 03:42 PM
Excel Formula minutes convert to hours Mal Soaring 27 December 15th 04 09:43 PM
Can I convert my D/C H10-76 to G.A. use? Jet Mech in Tampa Aviation Marketplace 1 May 28th 04 02:13 AM
