Homebuilt Question
Old January 1st 13, 03:49 PM posted to rec.aviation.piloting
Default Homebuilt Question
I'm wonder how this would play
out:
a. Person designs a unique plane,
one of a kind, no other ones to
compare it to.
b. It is a single-seater.
c. It has unique control surfaces,
and only someone "trained" can
fly it.
d. Gear is retractable.
e. Propulsion is "rather mysterious".
Now, how would this plane be certified?
No one else can fly it. Much of the
technology is sealed beneath carbon
fiber. No one knows how fast it goes.
It is homebuilt. Builder is willing to
concede that it isn't lightsport.
Thanks.
Mark
Old January 1st 13, 05:37 PM posted to rec.aviation.piloting
Mark IV[_6_]
out:
* *one of a kind, no other ones to
* *compare it to.
* *and only someone "trained" can
* *fly it.
No one else can fly it. *Much of the
fiber. *No one knows how fast it goes.
It is homebuilt. *Builder is willing to
Thanks.
Mark
It looks kinda like this, except no pusher prop,
or winglets. It has 11 control surfaces.
http://www.electravia.fr/Eclub/ECnoirA.jpg
How do I certify it?
Mark
Old January 1st 13, 07:30 PM posted to rec.aviation.piloting
Vaughn
Assuming you are in the USA, you certify it the same way you certify any
homebuilt airplane.
As always, Google is your friend in any search for knowledge. In this
particular case however, you might want to start with the EAA.
http://members.eaa.org/home/homebuil...ing/index.html
or at least: eaa.org/
Vaughn
Old January 1st 13, 11:20 PM posted to rec.aviation.piloting
Ron Wanttaja[_2_]
The answer is simple: It is an Experimental Amateur-Built aircraft. It
does not have to meet any certification standards. It only has to have
the required markings and the record-keeping to show that it was built
for "education or recreation". The unusual control system is moot, as
is the fact that it takes special training to learn to fly it. The FAA
doesn't care, for an Experimental Amateur-Built aircraft.
What MIGHT happen, though, is the FAA might assign a more-limited test
area, and require longer than the traditional 40 hour test period before
the plane can be flown outside the area.
out:
compare it to.
fly it.
Old January 2nd 13, 02:16 AM posted to rec.aviation.piloting
Mark IV[_6_]
On Jan 1, 5:20*pm, Ron Wanttaja wrote:
The answer is simple: *It is an Experimental Amateur-Built aircraft. *It
does not have to meet any certification standards. *It only has to have
for "education or recreation". *The unusual control system is moot, as
is the fact that it takes special training to learn to fly it. *The FAA
out:
* * one of a kind, no other ones to
* * compare it to.
* * and only someone "trained" can
* * fly it.
Thank you all for your input, as amateur-built
is new to me. Interesting note: Shortly after
posting my question I ran into a very nice fellow
(Joe) who was wearing a "Reno Air Races" ball
cap and we struck up a conversation. It wasn't
long before he was pulling photos out of his
wallet of the planes he built over the years, including
entries for Reno. His specialty now is Zenair STOL's.
Anyway, Joe's dad (who is in his 90's) has
served in some capacity with Flight Certification
over the years and much information was shared
with me. Seems the main thing is, they will need
entry ports of observation to check for safety wires,
and other such basic requirements. The time will
have to be flown off the plane, and technically,
being experimental, it isn't supposed to be flown
over population centers.
So... you all are right.
Thanks.
Mark
Old January 2nd 13, 04:34 AM posted to rec.aviation.piloting
Orval Fairbairn
In article
out:
* * compare it to.
* * fly it.
Thanks.
Mark
My question:
Why does it have to have a unique, nonstandard control system that
nobody else can fly without special training?
It seem to me that it violates a very important principle that has cost
dearly -- namely the KISS Principle, or: Keep It Simple, Stupid!
Old January 2nd 13, 03:33 PM posted to rec.aviation.piloting
On Tuesday, January 1, 2013 10:34:24 PM UTC-5, Orval Fairbairn wrote:
In article
The answer is simple: *It is an Experimental Amateur-Built aircraft.. *It
out:
* * compare it to.
* * fly it.
Thanks.
Mark
My question:
It's a little complicated, and goes all
the way back to the Horton Brothers, and
Mr. Northrop. Coming forward in time, look
at why Andrews Air Force base is named after
Mr. Andrews, and finally... we see why the
greatest airplane flying today, the B-2 Spirit,
as well as the X47B and others like it depend
on a "fly-by-wire" system directed with
software from the Moog corporation.
To maintain yaw and pitch authority within
limited moments at high g's.
Mark
Old January 2nd 13, 05:07 PM posted to rec.aviation.piloting
Orval Fairbairn
In article
out:
* * compare it to.
* * fly it.
Thanks.
Mark
My question:
Mark
It is Edwards AFB, named after Maj. Glen Edwards, who was kille in a
crash of the YB-49, not Andrews AFB.
If you have a FBW system, it is best to set up the manual controls so
that they emulate standard control systems -- a-la F-16, rather than
introduce a lot of specialty controls that you have to learn, and which
can get you into trouble in high workload situations.
The above-cited aircraft have controls which resemble standard controls
and respond in a similar fashion.
History question: homebuilt pushers [email protected] Home Built 7 May 3rd 07 04:51 PM
FSBO Question - rec.aviation.homebuilt Gary T. Ciampa Home Built 2 August 2nd 06 11:37 PM
homebuilt glider question Stealth Pilot Soaring 9 July 10th 06 10:40 PM
Electrical Question for Experimental Homebuilt Dick Home Built 1 March 30th 05 02:52 AM
question on intercoms for my new homebuilt w b evans Home Built 1 July 23rd 03 01:57 AM
