WinPilot locked up my Vertica 2 PNA - help!
Old January 1st 13, 03:31 PM posted to rec.aviation.soaring
Default WinPilot locked up my Vertica 2 PNA - help!
I've managed to lock my Vertica 2 PNA up with WinPilot, and can't get it un-frozen. Holding down the power button, even for an extended period doesn't do anything. Anyone know if there is a reset button?
If anyone else is trying to run WinPilot on a V2 in Landscape mode, DON'T launch the Declaration Transfer dialog! That particular dialog's 'OK' button is partially off-screen on the bottom and almost inaccessible. However, if you try to move the dialog up a bit so you can see/access the 'OK' button, it actually goes *DOWN*, and then the OK button isn't accessible at all, ever.
TIA,
Frank (TA)
Old January 1st 13, 04:07 PM posted to rec.aviation.soaring
bumper[_4_]
Frank (TA)
Reminds me of an early days MS-DOS LeadingEdge computer where you accidentally hit format and the screen says: "Format Drive C: - push any button to continue"
When you have no backup and your entire company customer database is on that damn computer, you do NOT want to push the ESC key. . . . I learned to hate computers from that.
bumper
Old January 1st 13, 04:18 PM posted to rec.aviation.soaring
Frank (TA)
bumper
Yep - can't live with them, can't live without them ;-)
Frank
Old January 1st 13, 05:20 PM posted to rec.aviation.soaring
TIA,
Frank (TA)
I couldn't find a hardware reset button at all, so I wound up disassembling the unit so I could unplug the battery, whereupon I found that the battery is *soldered* to the main PCB - Yikes!! Had to un-solder the B+ lead, then re-solder it to get the thing to reset. VERY scary :-(
Frank (TA)
Old January 1st 13, 05:22 PM posted to rec.aviation.soaring
son_of_flubber
I hope that you're not using your smartphone to post this from the air. You're on the ground right? Right?
Old January 1st 13, 08:04 PM posted to rec.aviation.soaring
Tom Kelley #711
On the back of the V2, is a very small hole. Not where the speaker holes are, but the opposite side. Using a very small wire, insert and then push the reset
button. Just like you would do on a IPAQ.
BUT the V2 stylist will not work as it doesn't go in deep enough. Which requires a small wire. Mine resets with no problem doing this.
Also, go to the Oudie Naviter site and theirs a good picture their.
#711.
Notes on the Vertica 2, Gliderguider PNA Tom Kelley #711 Soaring 19 November 1st 12 07:19 PM
Pilot locked in F22 601XL Builder Piloting 14 April 29th 07 06:19 PM
That's one way to get the gear down and locked Louis L. Perley III Piloting 17 September 19th 05 09:16 PM
WinPilot Offers Free WinPilot XP for your Desktop Computer Richard Pfiffner Soaring 0 November 8th 03 04:44 PM
