2-32 Canopy Needed
Old January 11th 13, 01:53 AM posted to rec.aviation.soaring
SoaringNV
Default 2-32 Canopy Needed
Does anyone have a lead on a replacement SGS 2-32 canopy. Ours is going to need to be replace before too much longer.
Thanks
Old January 11th 13, 04:08 PM posted to rec.aviation.soaring
aerodyne
On Jan 10, 5:53*pm, SoaringNV wrote:
Does anyone have a lead on a replacement SGS 2-32 canopy. *Ours is going to need to be replace before too much longer.
Thanks
Check K&L first, but I know that the place in LA (http://
www.ceebaileys.com/) is FAA/PMA approved and has molds for the
1-26/2-33. I have seen and installed their 1-26 canopy and it was
very well done. Most folks vastly underestimate the work involved in
locating and drilling the attach holes, the Cee Baily products are
predrilled. I believe Cee Baily has done the 2-32 before, but since
this one is moldless and free blown, I have seen some pretty bad
aftermarket canopies. At the least, you want to make a few templates
to make sure it has the right contour, and you don't end up with not
enough headroom. If the countour of your present canopy is off, as is
the one on 9851E, you might contact the owners of the "New" 2-32 at
Crystal with the original canopy, You could ask them to make a few
measurements for you.
Old January 12th 13, 01:59 AM posted to rec.aviation.soaring
Wheaton
Please email pa12joeataol.com
Old September 22nd 15, 06:23 PM posted to rec.aviation.soaring
Thanks
Are you still in the market for a 2-32 canopy?
Mike 303-817-2097
Baby Grob Canopy Needed Alpha One Soaring 12 March 9th 10 01:47 AM
Needed: LS-4 canopy [email protected] Soaring 1 May 18th 09 03:21 PM
SALTO canopy needed [email protected] Soaring 7 November 21st 08 02:45 AM
Blanik L-13 Front canopy sheet needed Roy Bourgeois Soaring 1 June 1st 06 11:31 PM
DART Canopy needed Ernie Soaring 2 January 17th 04 03:26 PM
