SeeYou for iPad and iPhone
Old January 21st 13, 08:01 PM posted to rec.aviation.soaring
Naviter Info
Default SeeYou for iPad and iPhone
It's been ready for quite a while but Apple was picky and it took several attempts to make them happy (you would have been happy much earlier
But now it's ready - SeeYou for iPad and iPhone!
http://www.naviter.com/2013/01/seeyo...ad-and-iphone/
You can find the flights from the World Championships in Uvalde and Gonzales Chaves if you run the app, press Menu Open from SeeYou Cloud Soaring Spot WGC choose your class, day and flight.
As with many developments from Naviter this winter - this is just the beginning!
Enjoy.
Andrej Kolar
glider pilots use
http://www.Naviter.com
Old January 21st 13, 09:10 PM posted to rec.aviation.soaring
Peter von Tresckow
Enjoy.
Andrej Kolar
glider pilots use
Awesome news Andrej. Have you given any thought to providing an Android or
iOS version of connect me? I would love to be able to rid myself of my
laptop that I still use to download my traces.
Pete
Old January 21st 13, 10:48 PM posted to rec.aviation.soaring
John Carlyle
Andrej,
I've been experimenting with it on my iPad the last 2 hours. Fantastic! Stupendous! Wonderful! Thank you very, very much!
-John, Q3
Enjoy.
Andrej Kolar
Old January 22nd 13, 01:28 AM posted to rec.aviation.soaring
On my iPhone I don't seem to have the maps. I just have a blue background. Any suggestions?
Lane
Old January 22nd 13, 01:31 AM posted to rec.aviation.soaring
Dave Nadler
Disable "BSOD Emulation" option ?
Old January 22nd 13, 01:52 AM posted to rec.aviation.soaring
If I zoom out the map is there but when I zoom in the flight area us just a blue background. If I scroll over a few miles outside of the flight area the map is appearing. It is as if it is being over written.
Old January 22nd 13, 08:20 AM posted to rec.aviation.soaring
Naviter Info
Are you on 3G/4G/LTE (i.e. not on Wifi)?
There's a setting which protects you from downloading lots of data without me asking if you want that.
The Settings on iOS are not inside the app, there's a dedicated "Settings" app (the one with the gear rings). At the bottom you will find SeeYou, then go to Data & Connection Download map tiles change "Wifi only" to "Wifi or Dataplan".
The setting is persistent. Set it once and forget about it.
Old January 22nd 13, 01:08 PM posted to rec.aviation.soaring
John Carlyle
I see the same behavior on my iPhone 4. When I zoom in so the screen is about 5 miles square, it becomes all blue. Zooming out restores maps on the side, but not in the old zoomed in region. If you slide the blue region off the screen (at the same magnification), the maps appear when you slide it back on. Behavior is the same if you select WiFi or Dataplan in the settings.
-John, Q3
Old January 22nd 13, 01:45 PM posted to rec.aviation.soaring
John Carlyle
I should add that the blue background on zoom-in occurs only on my iPhone 4.. On my iPad II (non-retina display) there is no problem - you can zoom in to the maximum magnification of the maps.
-John, Q3
-John, Q3
Old January 22nd 13, 02:33 PM posted to rec.aviation.soaring
You are correct. It was set to WiFi only.
Lane
IGC Reader for iPhone/iPad Jelle Vandebeeck[_2_] Soaring 13 October 25th 11 09:05 PM
AvCaddy EFB - iPad and iPhone SkytrexSystems Aviation Marketplace 0 July 21st 11 11:04 PM
Soaring Spot for iPhone/iPad Jelle Vandebeeck[_2_] Soaring 2 July 13th 11 05:06 PM
iPhone or iPad VFR GPS A L Instrument Flight Rules 3 January 17th 11 11:56 AM
iPhone or iPad VFR GPS A L Piloting 2 December 23rd 10 03:49 AM
