New glider from students of Politechnika Warszawska
Old February 11th 13, 07:38 PM posted to rec.aviation.soaring
RRK
Default New glider from students of Politechnika Warszawska
No plans for production.. Students exercise in design of electric gliders. Flays great. Sort of PW-7.
http://www.youtube.com/watch?v=poy8O...endscreen&NR=1
http://www.youtube.com/watch?v=MIpkwWF93vo
RRK
Old February 12th 13, 03:55 AM posted to rec.aviation.soaring
RRK
RRK
Could be a glider like this be used as a trainer ? How many take-offs are you making on electric self-lunch before it give up ?
Old February 12th 13, 02:10 PM posted to rec.aviation.soaring
waremark
An electric self launch Arcus 2 seat glider has a quoted endurance of 2,000 m of climb, after which you need a long recharge. That amount of climb should use about 5 litres of petrol in a solo engined version, which has a fuel capacity of 41 litres. So the electric version is heavier, costs a lot more and has far less endurance. Much as I like the quietness and simplicity of electric operation, battery technology has a way to go before electric self launching could be viable for a trainer.
RRK
Old February 12th 13, 05:47 PM posted to rec.aviation.soaring
Dave Nadler
The new "Charge+" feature increases that ~18% IIRC.
Also climb is proportional to weight; I don't remember at what
weight they quoted the figure above.
...So the electric version is heavier, costs a lot more and has
Absolutely. Its great for a launch and some saves, but absolutely
not for repeated take-offs as required in basic training. Antares
20E gets quite a bit more altitude as its lower weight than Arcus
(same motor and battery).
The Chinese trainer showed a few years back had hoped to include
quick-swap battery packs, but they've gone quiet after the structural
failure accident that killed Martin Wetzel (?sp). And the battery
packs are not cheap.
Electric trainers aren't going to happen until we see much better
cells (capacity per weight/volume and cost)...
Hope that's clear,
Best Regards, Dave
Students first flight in a 1-26 Wayne Paul Soaring 0 March 29th 12 04:11 AM
Two very fun students Bill Daniels Soaring 4 June 11th 06 11:24 PM
Aerodynamics for students? Richard Lamb Home Built 2 March 29th 06 05:07 AM
Postponed 3 students due to TSA Burt Compton Soaring 52 November 1st 04 09:34 AM
USA - All students must show Jim Vincent Soaring 0 October 19th 04 02:29 PM
