Schempp Hirth interior grey - paint match
Old February 24th 13, 08:55 PM posted to rec.aviation.soaring
Craig Funston[_2_]
Default Schempp Hirth interior grey - paint match
Looking to touch up the interior of my early 80's Nimbus and have been searching for that "just right" grey color in a rattle can (USA market). I've looked at Krylon, Rustoleum and Valspar. So far the Valspar "smoke infusion" color (85039) is closest, but it's still a bit on the light side. Anyone found the perfect match?
I can always go to my local industrial paint supplier and get a can of matched lacquer / enamel, but would rather avoid having to get out the spray equipment each time I want to do a part.
Craig
Old February 24th 13, 09:00 PM posted to rec.aviation.soaring
Vaughn
There's always Preval. http://www.preval.com/what-is-preval
Vaughn
Old February 24th 13, 09:20 PM posted to rec.aviation.soaring
Craig Funston[_2_]
Vaughn
Thanks Vaughn,
I've used them in the past. Still some cleanup time, but not as much as the full gun.
Craig
Old February 25th 13, 02:42 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Craig
Rust-oleum, pewter grey (7783) is a close match for Shempp-Hirth. Omni-pak F22508 is close to DG cockpit color. 2in1 primer grey is a good rattle can primer(4603) that I found at my local automotive paint store. I wire brush the rust off then cover everything but the item to be sprayed with an old sheet ( hole cut in the center). Best to remove the canopy to prevent over-spraying it.
Hope this helps,
JJ
Old February 25th 13, 04:40 PM posted to rec.aviation.soaring
Craig Funston[_2_]
Craig
Hope this helps,
JJ
Thanks JJ, I was hoping you'd pipe in.
Craig
Schempp-Hirth 2a/2b cockpit fit vs ASW-20? [email protected] Soaring 14 April 9th 12 01:46 PM
schempp-hirth shk-1 shkdriver Soaring 3 September 5th 08 03:38 AM
FS: Schempp-Hirth Discus A Tim Hanke Soaring 0 February 19th 06 02:16 PM
Schempp-Hirth Mel Dawson Soaring 0 February 15th 06 04:08 PM
Schempp Hirth or its Representatives... Chris OCallaghan Soaring 11 September 23rd 03 09:28 AM
