Slingsby Dart AD 98-22-15 update
Old March 7th 13, 10:04 PM posted to rec.aviation.soaring
Default Slingsby Dart AD 98-22-15 update
An NPRM has been published for updating the AD 98-22-15 that is applied to the Slingsby Dart sailplanes.
The current AD requires the 5-year repetitive “cutout” inspection per TI No. 109T51 Issue No. 2. This is a complex removal and replacement of a portion of the plywood wing skin to inspect the wing spar.
The new AD will require a repetitive annual inspection using an endoscope in existing drain holes in the lower wing skin per TI No. 109T51 Issue No. 3..
The current AD costs $3,400.00 (every 5 years) to complete while the new AD would cost $170.00 (every year) to complete (this info is per the SUPPLEMENTARY INFORMATION section of the AD).
This will be a great operating cost benifit to the current Slingby Dart owners, without compromising safety.
You can comment on this AD until 4-22-13. See futher informaiton at the following web site.
http://www.airweb.faa.gov/Regulatory...8?OpenDocument
Slingsby T.61 MotorFalke R. Wubben Soaring 11 December 10th 17 07:38 PM
Slingsby Dart [email protected] Soaring 1 September 6th 12 10:06 PM
Slingsby Skylarks.... George Ballantyne[_2_] Soaring 23 December 25th 08 08:21 AM
Slingsby Dart 17r handling notes Phil Collin Soaring 0 May 9th 07 10:07 AM
Slingsby T-21 Nyal Williams Soaring 14 March 1st 07 08:28 AM
