We don't need no steenkeeng one-man rig
Old March 19th 13, 07:52 PM posted to rec.aviation.soaring
Ralph Jones[_3_]
Default We don't need no steenkeeng one-man rig
How about a FIFTY man rig...;-)
http://www.youtube.com/watch?v=V2D3k0sJ8HM
Old March 19th 13, 09:35 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Amazing. I would have never guessed that a P-4 could be assembled like
that and flown away, but I suppose something like that must have been
possible for any WW2 war that didn't have the range or carrier capability
for self delivery to its operational area, i.e. in the North African,
Burmese and Pacific theatres.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old March 19th 13, 11:42 PM posted to rec.aviation.soaring
Key Dismukes
Not that different from some gliders i've helped rig!
Key
org |
Old March 20th 13, 12:11 AM posted to rec.aviation.soaring
BobW
Amazing. I would have never guessed that a P-47 could be assembled like
possible for any WW2 [plane] that didn't have the range or carrier
capability for self delivery to its operational area...
Nifty!!! I've long wondered why the Schweizer boys overlooked the
ease-of-rigging enhancement otherwise known as the fuselage dolly when they
designed all their glider trailers. Watching this film may have been the
reason!!! :-)
Lay the wings on the ground, indeed...
Old March 20th 13, 02:45 AM posted to rec.aviation.soaring
Tom K (ES)
Reminds me of my Lak-12...
Old March 20th 13, 04:04 PM posted to rec.aviation.soaring
Dan Marotta
What??? The 1,800 lb wing?
I used to be the only one who *didn't* disappear when Dave R. got his LAK-12
fuselage out of the trailer... So I moved!
"Tom K (ES)" wrote in message
Old March 20th 13, 07:28 PM posted to rec.aviation.soaring
Bill D
Let's see...
The FAA certified it as meeting the 51% rule and the GI's got their Repairman's Certificate.
Old March 20th 13, 07:44 PM posted to rec.aviation.soaring
Bill D
That P-47 wing had a self-sealing fuel tank, 4, .50 cal gun mounts with ammunition trays and numerous hard points for bombs and rockets. It also had a main gear leg to support all that weight. The fuselage had pilot armor and heavy vacuum tube avionics. "Civilianized" WWII fighters often weighed a ton less than the GI versions after they were stripped of the mil-stuff.
I was surprised to see so few men lifting the propeller. Those had steel blades with silver solder contouring the airfoil. They were seriously heavy.
Old March 20th 13, 08:42 PM posted to rec.aviation.soaring
Ralph Jones[_3_]
On Wed, 20 Mar 2013 12:44:01 -0700 (PDT), Bill D
[snip]
About 10,000 lb empty, 17,000+ MGTOW. Actually the guns, which
accounted for about 350 lb per wing, wouldn't have been installed
until after assembly.
About 400 lb, IIRC.
Old March 21st 13, 04:45 PM posted to rec.aviation.soaring
kirk.stant
On Wednesday, March 20, 2013 8:44:01 PM UTC+1, Bill D wrote:
That P-47 wing had a self-sealing fuel tank, 4, .50 cal gun mounts with ammunition trays and numerous hard points for bombs and rockets. It also had a main gear leg to support all that weight. The fuselage had pilot armor and heavy vacuum tube avionics. "Civilianized" WWII fighters often weighed a ton less than the GI versions after they were stripped of the mil-stuff..
Minor detail - P-47s didn't get internal wing tanks until the late-war P-47N model. If this is a C, it wouldn't even have wing bomb/drop tank racks.
Still a big hunk of metal!
Kirk
66
