LXSIM problem
Old March 24th 13, 03:06 PM posted to rec.aviation.soaring
Sam Zimmerman
Default LXSIM problem
Has anyone mastered the LXsim program? I have loaded the North American
database but can't get the simulator aircraft to leave Slovakia. I loaded
Perry TPs and a task, have tried "starting" the task, but get nothing but a
flight near Celjic(?). Any pointers would be appreciated.
Old March 24th 13, 04:42 PM posted to rec.aviation.soaring
Dan Marotta
Maybe getting a local GPS fix which will be stored in your initialization
file(s). At least that's how it (looks like it) works with XCSoar.
I found, with XCSoar, that it started off somewhere in Europe. Running it
on my PC, I boosted the speed to about 7,000 Kts and "flew" it to New
Mexico. Pretty tedious! But, I found that, when I ran it on my Streak with
a GPS fix, it flew locally. I transferred my data files to my PC (IIRC) and
it worked in the states.
I don't know if you can do likewise with your LX, but it might be worth a
try.
"Sam Zimmerman" wrote in message
m...
a flight near Celjic(?). Any pointers would be appreciated.
Old March 24th 13, 05:21 PM posted to rec.aviation.soaring
John Galloway[_1_]
initialization
Running it
to New
Streak
with
(IIRC)
and
be worth a
try.
om..
Old March 24th 13, 09:05 PM posted to rec.aviation.soaring
Muttley
Hi
Go to Program Files/LXNAV/LXSim/Data
rename the earth.cit file into something like oldearth.cit
copy the .cit file from your region into this same location and
rename it earth.cit
That is the way i got my simulator to work on my own local area (Ireland)
to fly tasks etc.
Mottley
Old March 24th 13, 09:39 PM posted to rec.aviation.soaring
waremark
I was not able to make it work in portrait mode - the bottom row of buttons is not available. Have others had this problem?
Old May 28th 14, 05:41 PM posted to rec.aviation.soaring
I have the same problem but solved it by rotating the laptop screen 90 degrees, not very elegant, but at least you get the full portrait screen, which if you are going to have a portrait setup in your glider, you need.
Old May 30th 14, 01:57 AM posted to rec.aviation.soaring
Dave Springford
The latest version if LX Sim has a "screen scale" menu item where you can now shrink the LX9000 portrait layout to fit your PC screen.
Dave Springford
www.foxonecorp.com
Old May 30th 14, 01:59 AM posted to rec.aviation.soaring
Dave Springford
The latest version of LX Sim has a "screen scale" menu item where you can shrink the LX9000 portrait layout to fit your PC screen and see all of the buttons.
Dave Springford
www.foxonecorp.com
Old May 31st 14, 10:12 PM posted to rec.aviation.soaring
Have you tried naming a local glider port as "home". In most sims this gets you to familiar territory on start up.
Lane
Old March 24th 13, 11:46 PM posted to rec.aviation.soaring
Sam Zimmerman
where would I find a .cit file for my region?
"Muttley" wrote in message
a
Hi
rename it earth.cit
to fly tasks etc.
Mottley
Is there a problem with rah? Scott Home Built 48 February 8th 07 01:45 PM
New Problem with FS9, help please!! Chuck Dreier Simulators 3 December 19th 04 06:21 PM
ADF Problem tony roberts Instrument Flight Rules 14 May 12th 04 02:59 AM
Problem with this NG? Regnirps Military Aviation 10 April 29th 04 03:39 PM
do I have an ADF problem ? Dave Jacobowitz Instrument Flight Rules 6 April 1st 04 12:58 AM
