Mech vario - Static vs TE?
Old April 5th 13, 02:53 AM
dbrunone dbrunone is offline
Member
First recorded activity by AviationBanter: Oct 2011
Default Mech vario - Static vs TE?
Quick question -- for a mechanical vario (such as Winter), do most people hook up the static port to the TE probe, or the static line? It seems the TE probe would naturally compensate the vario for stick movements, but is there a disadvantage?
Old April 5th 13, 01:39 PM posted to rec.aviation.soaring
On Thursday, April 4, 2013 9:53:00 PM UTC-4, dbrunone wrote:
Quick question -- for a mechanical vario (such as Winter), do most people hook up the static port to the TE probe, or the static line? It seems the TE probe would naturally compensate the vario for stick movements, but is there a disadvantage? -- dbrunone
Connect to total energy probe.
If used with a non flow type electric variometer, connect in parallel and with at least 6 feet of tubing from where the TE lines from the vario join to the TE source line.
UH
Old April 5th 13, 02:14 PM posted to rec.aviation.soaring
Kevin Christner
I would recommend splitting the TE line as far back from the
instrument as possible (6 feet is probably plenty, but more doesn't
hurt) to avoid interference. Otherwise the varios seem to "play" with
each other and you get pretty bad compensation.
2C
UH
Old April 5th 13, 07:24 PM
Member
It will be in parallel with an LXNAV V7 vario (which is non-flow-type, as I understand). But 6 feet to each instrument?? That sounds like an awful lot...that's 12ft of tubing coiled up under my panel! I should have room though. I really makes that much of a difference huh?
Old April 6th 13, 06:05 PM posted to rec.aviation.soaring
I use to have a Borgelt B-50 in my HP-14. It was installed as prescribed in
the B-50 manual.
http://www.borgeltinstruments.com/B50man.pdf
" The T-piece in the T.E. line should be as close as possible to the T.E.
probe although in practice it has been found that if the T.E.
line is split under the pilot's seat, further aft behind the seat or near
the trailing edge of the wing no problems will result."
With the turtle-back off the '14 it was easy to put the T-piece in the
tail-cone aft of the trailing edge of the wing.
http://tinyurl.com/N990-6F
"Kevin Christner" wrote in message
2C
UH
Tasman Vario on Static 5Z Soaring 0 April 19th 11 01:56 AM
Tasman Vario on Static Tony[_5_] Soaring 12 April 15th 11 09:14 AM
Pilot vs Mech James Huber Home Built 0 October 20th 07 02:04 AM
Winter Mech Vario Bezel Mike Hostage Soaring 2 March 29th 05 05:42 AM
WTB: (USA) Mech Vario 57mm(2-1/4) Knots Curtl33 Soaring 7 January 24th 04 03:31 AM
