SZD-51-1 Junior Technical Service Manual
Old April 5th 13, 03:21 PM posted to rec.aviation.soaring
Jonathan Hughes[_2_]
Default SZD-51-1 Junior Technical Service Manual
Does anyone have a soft copy of the Technical Service Manual for a
Junior that they could send to me? Our club can't locate one and we need
the procedure for the weight and balance. Specifically, we need to know
how high to raise the tail when weighing the glider.
Thanks!
--Jonathan
Old April 6th 13, 02:12 AM posted to rec.aviation.soaring
Dave Springford
I need to double check, but I believe the level datum for the Junior is trailing edge level with the middle of the leading edge.
I'll try to find the official reference.
Old April 6th 13, 02:23 AM posted to rec.aviation.soaring
Dave Springford
From the Canadian Type Certificate Data Sheet:
"The glider, when weighing for definition of c.g. location and mass value, shall be attituded so, that the wing root-chord /wing chord in wing-to-fuselage plane is level."
Paragraph 21 on page 5 of the TCDS that you can download by clicking on the VIEW PDF Icon on this page:
Tiny URL: http://tinyurl.com/dx7z5hr
Original URL:
http://wwwapps.tc.gc.ca/saf-sec-sur/...bid_n um=1027
Old April 6th 13, 02:42 AM posted to rec.aviation.soaring
Tony[_5_]
I'm a cfi-g and apparently have an aerospace engineer degree and have no idea wtf that's means. How do you measure it? What do you measure? Hiwnis your average a&p supposed to figure it out?
Old April 6th 13, 02:49 AM posted to rec.aviation.soaring
son_of_flubber
What this means, quoted from the tech manual
"The supports should be located under the main and tail wheels. The difference of height should be adjusted so that the trailing edge of wing root rib and the wing leading edge (leveling mark) are on the same level."
Jonathan got a soft copy of the tech manual today and posted it on his club website flybasa.org
Old April 6th 13, 03:53 AM posted to rec.aviation.soaring
Tony[_5_]
How do you level an imaginary line that goes through the wing? As usual someone forgot to make the engineers actual perform the procedure.
Old April 6th 13, 04:33 AM posted to rec.aviation.soaring
Tim Taylor
The engineer was holding a simple tube for a water level.
Old April 6th 13, 01:27 PM
Matt G. Matt G. is offline
Junior Member
First recorded activity by AviationBanter: Jul 2012
Quote:
Kind of like checking the aileron deflections on an SH1 with that imaginary point floating aft of the TE of the aileron :P
Old April 6th 13, 03:42 PM posted to rec.aviation.soaring
Thanks to Flubber's Son we got the information that we needed. We're
going to weigh our Junior this morning.
--Jonathan
PIK-20 POH/SERVICE MANUAL James Anderson Soaring 1 October 24th 12 09:35 PM
Blanik L-13 Technical Manual nimbus Soaring 0 February 14th 10 11:19 PM
WTB: King KNS-80 Service Manual DanD Instrument Flight Rules 0 January 9th 04 10:24 PM
KI-214 Service Manual Jim Weir Home Built 1 September 30th 03 09:28 PM
KI-214 Service Manual Jim Weir Owning 1 September 30th 03 09:28 PM
