ILEC SB 9 vario problem
Old April 9th 13, 03:24 PM posted to rec.aviation.soaring
Chris
Default ILEC SB 9 vario problem
After the winter break my Ilec SB 9 backup vario is declining to work.
When switched on (regardless of position V1, V2 or Res - and also on back up battery power and Res), the needle deflects to fully negative and stays there (with a muted humming sound) until switched off. I checked plumbing and electrical connections and could not find anything wrong. Removed from the glider - same thing on back-up battery power and Res.
Two questions:
- Anybody seen this behavior and can tell me what is wrong?
- Where can I get this vario repaired?
Any help much appreciated.
Thanks, Chris
Old April 9th 13, 04:58 PM posted to rec.aviation.soaring
Tom[_12_]
ILEC variometers are extremely reliable, however, things do happen.
Be sure you have hooked up the battery in the correct polarity.
Probably best to return the unit to ILEC for repair and calibration.
Tom
Looking for an ILEC SB-9 vario Dave Nadler Soaring 0 March 30th 11 10:28 PM
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario ufmechanic Soaring 0 March 24th 09 05:31 PM
FS: ILEC SB8 Acoustic Vario / Speed Commander Michael Huber Soaring 0 December 17th 07 02:07 PM
FS: Ilec SB-9 (US) [email protected] Soaring 0 December 2nd 06 11:44 AM
L-Nav audio vario problem Roy Clark, B6 Soaring 5 September 8th 05 04:58 AM
