PowerFLARM Transponder Alert Size
Old May 4th 13, 03:14 PM posted to rec.aviation.soaring
John Carlyle
Default PowerFLARM Transponder Alert Size
Does anyone know the PowerFLARM transponder ADS-B and PCAS default alert size? This would be analogous to the Zaon MRX settings, like 5 mile radius with an altitude of +/- 2000 feet, inside of which it sounds a warning. I haven’t found a way to set the alert size in PowerFLARM, just the maximum range and maximum vertical range.
-John, Q3
Old May 5th 13, 07:17 PM posted to rec.aviation.soaring
Andy[_1_]
Dataport specification for sentence PFLAA may be worth a read. For
PowerFLARM core the warnings will, I assume, depend on what the
display system does with the available data.
The definition of PFLAA includes "PFLAA sentences are limited to other
aircraft with a horizontal distance of less than the configured
horizontal range (default is 3km) and a vertical separation of less
than 500m. Non-moving aircraft are suppressed." also included in
PFLAA (with yellow highlight) "Non-directional targets (transponder
mode C/S; protocol version 6 and higher) are only output as PFLAA
sentences."
The definition for PFLAU includes (with yellow highlight) "Only
directional targets (i.e., with a known relative bearing) are output
as PFLAU sentences."
Based on a quick read I assume that the alert volume is the same for
all target signal types and that only the range can be user defined.
Andy
Old May 6th 13, 04:33 PM posted to rec.aviation.soaring
John Carlyle
sentences."
Andy
Good catch, Andy, thanks for the tip. I agree, it appears that the alert "bubble" size is fixed, and that only the acquisition range and height can be changed.
I'm now trying to decide what my range and height limits should be. Seeing airliners 30,000 feet above me and 15 nm away is cool, but not particularly helpful. I guess I'll try a range of 9,500 m and a height of 900 m and see how that works in the crowded PHL-EWR area.
There's another problem I've got to solve, and that's the PowerFLARM PCAS function occasionally triggering on my own transponder. I've triple checked that the transponder's ICAO-24 hex code is the same as the PowerFLARM's aircraft ID, but every 5 minutes or so it displays a PCAS alert on myself. Turning the transponder off solves the problem, but that's scary where I'm flying. Maybe limiting the range and height will alleviate this problem? We'll see...
-John, Q3
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
Transponder vs. Portable Transponder Detectors John Murphy Soaring 16 December 20th 08 07:25 AM
Klewless newbie alert! (Was Troll alert! Why is "CovvTseTung" using multiple aliases here?) Maxwell[_2_] Piloting 76 August 22nd 08 04:07 PM
What size hole saw do I use? [email protected] Home Built 22 July 16th 05 08:21 AM
