Trouble with Cambridge Utility
Old May 7th 13, 07:04 AM posted to rec.aviation.soaring
Wade
Default Trouble with Cambridge Utility
I attempted to export (file/save as) a group of 75 waypoints chosen in the See You desktop version for use in a Cambridge 302 (.dat file) The waypoints in See You were from the original seeyou.cup file that came with the software when I bought it. When I try to upload the .dat file to the 302 using the cambridge utility, the utility crashes. It works if I drop the total number of waypoints to 18 and it seems to be any 18 waypoints I choose.
If I use waypoints from the turnpoint exchange then it works just fine. This seems like an easy solution but I actually like having the waypoint data that the seeyou.cup file gives such as airport frequencies etc... that aren't given in the turnpoint exchange files.
If anyone has run across this and understands what is going on I would appreciate the help. I am assuming that there is trouble with the format of the content within the .dat file but I don't know what I should manually alter it to.
Thanks
Wade
Old May 7th 13, 01:49 PM posted to rec.aviation.soaring
Paul Remde
Hi Wade,
I use SeeYou to generate waypoint files for the 302 often. After I save the
..dat file I use Notepad to add an "H" attribute to the home airport.
I can't explain the error you are seeing. Did you edit the file in Word?
Word could add some hidden characters.
Try using SeeYou or ConnectMe to upload the waypoint file to the 302.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
________________________________________________
"Wade" wrote in message
choose.
alter it to.
Thanks
Wade
Old May 7th 13, 05:22 PM posted to rec.aviation.soaring
2KA
Wade,
Try creating your turnpoint file using my website at http://www.soaringdata..info. Select the Airports tab. You can make a .CUP file with any of several levels of selectable comment detail, together with a companion Cambridge .DAT file that contains the same points. The length of the comments in .DAT files is quite restricted, but I have concocted a short format that does include radio frequencies runway information. That format is explained on the site as well.
If you have any questions, email me using the "Questions or Comments" link on the site.
Lynn Alley
"2KA"
Old May 9th 13, 06:08 AM posted to rec.aviation.soaring
Wade
Thanks Paul,
I didn't do any editing with word or a text editor of any kind. The file was the original seeyou.cup file that comes when I bought the pc version. I think it just has too much information in the file which is why it lets me do 18 waypoints and no more.
Thanks
Wade
On Tuesday, May 7, 2013 5:49:07 AM UTC-7, Paul Remde wrote:
Hi Wade,
Best Regards,
Paul Remde
choose.
alter it to.
Thanks
Wade
Wade
I will go do that right now. Thanks for the help and for the website.
Wade
On Tuesday, May 7, 2013 9:22:03 AM UTC-7, 2KA wrote:
Wade,
Try creating your turnpoint file using my website at http://www.soaringdata.info. Select the Airports tab. You can make a .CUP file with any of several levels of selectable comment detail, together with a companion Cambridge .DAT file that contains the same points. The length of the comments in .DAT files is quite restricted, but I have concocted a short format that does include radio frequencies runway information. That format is explained on the site as well.
Lynn Alley
"2KA"
Old May 9th 13, 06:12 AM posted to rec.aviation.soaring
Wade
Do you have a lot of information displayed in the .dat file after you do a save as from within see you?
Hi Wade,
Best Regards,
Paul Remde
choose.
alter it to.
Thanks
Wade
Hi Wade,
Best Regards,
Paul Remde
choose.
alter it to.
Thanks
Wade
Old May 9th 13, 12:48 PM posted to rec.aviation.soaring
Paul Remde
Hi Wade,
Using SeeYou to export waypoint files in the .dat Cambridge format works
great. But you need to limit the number of points in the file. It is easy
to do.
I don't recommend using the waypoint file that comes with SeeYou. Get the
latest file for the entire USA he
http://soaringweb.org/TP/FAA - Download the SeeYou .cup file.
Then open the file in SeeYou. Do not append the data to existing data.
Then take a look at the SeeYou training video I created on this subject. It
is available he
http://www.cumulus-soaring.com/train...raining-SeeYou - Video #29
Let me know if you have any questions.
Paul Remde
Hi Wade,
Best Regards,
Paul Remde
waypoints
choose.
This
of
alter it to.
Thanks
Wade
Hi Wade,
Best Regards,
Paul Remde
waypoints
choose.
This
of
alter it to.
Thanks
Wade
Old May 11th 13, 03:54 AM posted to rec.aviation.soaring
Wade
Thank you to everyone for helping me out with this. Honestly I am very pleased with the setup on soaringdata.info and I especially like the feature where I can take a waypoint database from soaringdata, upload the cup file into see you, make changes adding waypoints and tasks and implement my changes back into soaringdata site again where it allows you to provide your own points / tasks you want added and run another iteration getting a combined cup file and dat file. Great stuff!
Thanks
Wade
Thanks
Wade
Cambridge 302 Utility app [email protected] Soaring 1 June 7th 12 03:59 PM
Cambridge 302 download utility unavailable. Copy anyone? Kurt Thams Soaring 6 April 30th 12 03:46 PM
Cambridge Utility software Bob 7U Soaring 4 September 5th 11 06:18 PM
Cambridge Utility Program Question Scott Alexander[_2_] Soaring 4 February 9th 10 07:34 PM
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 Nathan Whelchel Soaring 4 July 5th 04 11:22 PM
