XC Soar Map Generator link down
Old May 7th 13, 05:55 PM posted to rec.aviation.soaring
Sean F (F2)
Default XC Soar Map Generator link down
Hi all. Just tried to build a map for Bermuda High, South Carolina, USA and the Map Gen link gave the following error...
502 Bad Gateway
nginx/0.8.54
Any chance of getting this corrected or if you are working on it, an ETA? Thanks in advance!
Sean
F2
Old May 7th 13, 05:59 PM posted to rec.aviation.soaring
Tobias Bieniek
Hi Sean, the server that hosted the mapgen has died a couple of days ago. We are working on setting it up again, and it should be online again by the end of the week or sooner.
Turbo
Old May 7th 13, 06:09 PM posted to rec.aviation.soaring
Sean F (F2)
Turbo
Thanks Tobias. That puts me in a bit of a tight spot. Day 1 is tomorrow! Shame on me for not downloading this sooner.
Any chance of generating a high res (or low res) map for the Bermuda High, SC (2013 18 Meter US Nationals) contest area and emailing it to me at SMFIDLER AT GMAIL DOT COM?
Thanks in advance!!!
Sean
Old May 7th 13, 06:16 PM posted to rec.aviation.soaring
Turbo
Sean
Sean,
Not to worry - there's no real 'terrain' associated with Bermuda High anyway - it's all FLAT! ;-)
TA
Old May 7th 13, 08:15 PM posted to rec.aviation.soaring
The one I generated last year is on the way...
Old May 7th 13, 09:34 PM posted to rec.aviation.soaring
Tobias Bieniek
can you give me some coordinates? upper left and lower right corner of the area would be enough.
Old May 7th 13, 11:30 PM posted to rec.aviation.soaring
On the turnpoint list they're using for the 18m Nationals, the range of
latitude is 34d08' to 36d08' North and the longitude range is 78d34'
to 81d59' West. I'd extend that about 50km so that any possible AATs
would not go too close to the edge. As it is I gave Sean the map I
generated last summer for flying in that area (which overlaps my home
area somewhat).
Actually, how are the "permanent" areas on the map decided? This year
Region 5 in the US is hosting the most contests of any region in the
country (Seniors, R5N, 18m, R5S, R5W, and Standard) but yet there aren't
any maps for the region unless you generate your own.
Matt
Old May 8th 13, 12:51 PM posted to rec.aviation.soaring
Tobias Bieniek
They were once imported from the LK8000 project and filtered for duplicates and overlapping areas. If you feel that some are missing then please tell us you suggestions with name and coordinates.
They should be rather generic and not bound to certain competitions. For example there is just a single map for Germany, one for the Alps, one for France, ... I don't know how well that maps to the US, but I could imagine grouping certain states together into useful maps.
Old May 8th 13, 02:16 PM posted to rec.aviation.soaring
Surge
The map generator site is working again and I successfully generated a map (Magaliesburg, ZA).
Thanks for fixing it Tobias (or whoever did the work in the background).
Old May 8th 13, 02:56 PM posted to rec.aviation.soaring
OK, interesting. Actually there's a few Soaring Meccas through the general
region -- Florida (12 months of soaring a year), Carolinas (most popular
US contest and also popular commercial operation), Tennessee/Georgia (weekend
race series) and the Blue Ridge and Shenandoah Valley (long ridge flights
from several clubs along its length).
I'll suggest some after consideration. Also for consideration might be to
post xcm files to the turnpoint exchange. I'll ping John and see if that
would be interesting.
Matt
OLC - 2008 - DO NOT USE 2007 URL LINK, or current ssa.org link [email protected] Soaring 1 October 25th 07 05:37 PM
'A' or 'B' generator circuit? jim Owning 1 August 8th 06 02:02 AM
generator mufflers Lou Home Built 37 July 17th 06 11:16 PM
E5-A generator-12V,50A jerry wass Restoration 0 April 8th 06 04:47 AM
E5-A Eclipse 12V-50A Generator jerry wass Aviation Marketplace 0 April 8th 06 03:50 AM
