How do gas struts fail on clamshell trailer? Will the lid drop suddenly?
Old May 15th 13, 04:58 PM posted to rec.aviation.soaring
son_of_flubber
Default How do gas struts fail on clamshell trailer? Will the lid drop suddenly?
One of the lifting struts on my clam shell trailer lid is failing (partially or completely). It will not lock in the fully opened position so the lid sags down a few inches on that side. I suspect that the second strut is holding the entire weight. However, the lifting force required of my body to raise or lower the lid is symmetrical, so maybe both struts are providing some lifting force. Maybe the strut on the right has just lot the ability to "lock" in the fully extended position??
Yesterday I was assembling in gusty conditions. Both wings were on and when I turned around to get the horizontal stabilizer out of the trailer, I found that the lid had slowly closed. I'm trying to get two new struts ASAP and in the meantime I can live with a lid that slowly closes in gusty conditions.
What concerns me is the possibility that the lid will close suddenly and damage the lid, the glider or a person. Does this happen? Can a strut fail completely and suddenly, or is the deterioration gradual?
Maybe I should assemble the glider on a calm day and leave it tied out until I can replace the struts. Or maybe I should make some sort of brace from some 2X4's that will keep the lid from closing.
Old May 15th 13, 05:35 PM posted to rec.aviation.soaring
Papa3[_2_]
What you're describing (gradual decrease in lifting force) is the typical failure mode I've seen. Note that it's also somewhat temperature dependent, so it's worse on cold days. I would definitely invest in a 2x4 or equivalent that you can jamb into the gap to temporarily backstop the struts. The real worry is that the clamshell comes down a little faster one day, just as you're pulling a wing or fuselage out.
P3
Old May 15th 13, 05:32 PM posted to rec.aviation.soaring
Peter von Tresckow
Some trailers (Eberles IIRC) have struts that are put into place to assure
the lid stays open. I wouldn't want to trust a gas shock to keep the lid
open. Go to Home Depot, and get a 2x4.
Pete
Komet Trailer Struts Steve Mason Soaring 4 March 28th 13 12:59 AM
looking for used Clamshell trailer Brad[_2_] Soaring 0 June 26th 11 09:57 PM
looking for clamshell trailer Brad[_2_] Soaring 4 November 10th 08 03:30 AM
Cobra trailer lift struts for clamshell top [email protected] Soaring 4 March 4th 08 11:55 AM
Gas Struts for Clamshell Trailer [email protected] Soaring 1 April 26th 05 02:49 AM
