Moriarty Winds
Old May 19th 13, 11:17 PM posted to rec.aviation.soaring
Dan Marotta
Default Moriarty Winds
This from a friend at the airport:
Winds at 0E0 right now at 240 degrees, 31 gusting to 37 with flying
tumbleweeds, cats, dogs and coyotes......in haze and blowing dust. Bart is
now being blown eastward back to his home in Kentucky against his will. He,
however, will have to get past the tornadoes currently on the ground in
central Oklahoma....If he intersects them it may speed up his "flight" east
bound...
Old May 24th 13, 05:46 PM posted to rec.aviation.soaring
tstock
bound...
Tornado no problem just fly against the direction of rotation right? Which is negative ground speed btw.
Old May 24th 13, 07:06 PM posted to rec.aviation.soaring
Mike the Strike
Sounds like a perfectly normal wind for Moriarty!
Old May 26th 13, 05:13 PM posted to rec.aviation.soaring
Dan Marotta
Today's forecast is for 20-30 G 40. Ground handling is really the tough
part.
"Mike the Strike" wrote in message
Old May 27th 13, 01:03 AM posted to rec.aviation.soaring
son_of_flubber
part.
In what month do these winds abate?
Old May 27th 13, 06:24 AM posted to rec.aviation.soaring
Mike the Strike
The 29th of February is usually quite calm!
Old May 27th 13, 05:36 PM posted to rec.aviation.soaring
Dan Marotta
Winds are beginning to taper off. And it's a good thing with the contest
starting in about a week.
Old May 27th 13, 06:04 PM posted to rec.aviation.soaring
Dan Marotta
On my last flight, just a few days ago, winds at landing were about 40
degrees left at 19G29 making the crosswind runway useless. Fortunately our
runway is about 75 ft wide and we have a very large turnout so, if you carry
sufficient energy and you know how your brakes work, it's more exciting than
scarey. It helped a bit, too, that my left water dump valve was stuck (ice,
maybe) and that made keeping the left wing level against the wind pretty
simple until I came to a stop.
Old May 28th 13, 08:41 PM posted to rec.aviation.soaring
Tony[_5_]
On Monday, May 27, 2013 11:36:19 AM UTC-5, Dan Marotta wrote:
Winds are beginning to taper off. And it's a good thing with the contest starting in about a week. "Mike the Strike" wrote in message ... The 29th of February is usually quite calm! Mike
the winds just moved over to Kansas...
Old May 30th 13, 03:32 PM posted to rec.aviation.soaring
Mike the Strike
Wanna bet?
Another Great Day at Moriarty Dan Marotta Soaring 2 May 9th 13 12:55 AM
New Runway at Moriarty! [email protected] Soaring 5 December 22nd 12 02:50 AM
Looking for tow Moriarty to Minden pat Soaring 0 June 22nd 11 01:34 PM
Soaring at Moriarty, NM Renny[_2_] Soaring 6 October 5th 10 05:05 AM
Yippee! Soaring in Moriarty, NM Chris Soaring 2 March 21st 04 12:03 PM
