Need help converting .cup file to .dat file
Old May 22nd 13, 06:17 AM posted to rec.aviation.soaring
nimbus[_2_]
Default Need help converting .cup file to .dat file
Trying to find a link to a site that will convert my .cup waypoint file to a .dat file. I've tried the GPS babel site ( http://www.gpsvisualizer.com/gpsbabel/ ) with no luck unless I'm just selecting the wrong extension options.
Thanks for any help.
Old May 22nd 13, 10:45 AM posted to rec.aviation.soaring
Willy VINKEN
Filename extensions are not unique (have a look at
http://www.filesuffix.com/).
In a soaring context, let's suppose that '.cup' is used with SeeYou,
and '.dat' files are to be uploaded to some Cambridge hardware.
In this case, both are actually '.txt' files with a specific suffix.
Change '.cup' and '.dat' to '.txt', and open them with Notepad (or
Wordpad, ou Word...).
This will show you how data are to be arranged and formatted.
Once you have the example, it is a simple matter to open the original
'.cup' file in Excel, (Open as 'Text file' [¨.prn;*txt;*csv]),
re-arrange data, concatenate them as required,
save the result as a '.txt' file and rename it to '.dat'.
Willy VINKEN
On Tue, 21 May 2013 22:17:15 -0700 (PDT), nimbus
Old May 22nd 13, 11:24 AM posted to rec.aviation.soaring
Le mercredi 22 mai 2013 07:17:15 UTC+2, nimbus a écrit*:
Open the .cup file in SeeYou and save it in .dat format.
Old May 22nd 13, 01:39 PM posted to rec.aviation.soaring
Paul Remde
Hi,
You may want to check-out my SeeYou training videos related to importing and
exporting waypoint files he
http://www.cumulus-soaring.com/train...raining-SeeYou - Specifically
videos 28 and 29
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
_____________________________________
"nimbus" wrote in message
..dat file. I've tried the GPS babel site (
Old May 22nd 13, 02:46 PM posted to rec.aviation.soaring
CLewis95
The GPSVisualizer Utility you tried has worked for me many times. Make sure you are setting Input and Output selections as he
Type of GPS data you want to convert:
Input file format: See You flight analysis data [W]
Output file format: Cambridge/Winpilot glider software [W]
Curt - 95
Old May 22nd 13, 03:52 PM posted to rec.aviation.soaring
nimbus[_2_]
Thanks all for you responses. Got it.
Old May 22nd 13, 04:07 PM posted to rec.aviation.soaring
2KA
You can also use my website at http://www.soaringdata.info. Go to the "Aiports" tab and follow the first link. Upload your .dat file, and chose the "Don't add any airports" drop down option.
In addition to converting the file, it will also refresh information (like radio freqs) for US airports.
Lynn Alley
"2KA"
Old May 2nd 16, 04:29 AM posted to rec.aviation.soaring
xcnick
Old thread but I will ask anyways.
soaringdata.info and gpsbabel both eliminate the name, not good.
gpsvisualizer has the cambridge listed with a (T) as if it did tracks not waypoints. Cambridge/Winpilot glider software [W] not an option 2016
Old May 2nd 16, 04:47 AM posted to rec.aviation.soaring
2KA
Hi xcnick,
Not sure what you mean by "eliminate the name". That certainly isn't usual behavior -- names are generally translated between formats just fine, as many pilots will attest.
Please contact me using the "Questions and Comments: link on http://www.soaringdata.info, and send me the .dat file you are working with and some detail regarding what is wrong. I bet I can help get it resolved.
Lynn Alley
"2KA"
Old May 2nd 16, 07:53 AM posted to rec.aviation.soaring
xcnick
Thanks, sent
Nevada's Great Basin data at the turnpoint exchange converting from .cup to .dat
Converting CUP file to TXT file og Soaring 6 December 1st 10 05:30 PM
Interesting view of world wide air traffic in 24 hours (WMV - read the zero file) - File 1 of 1 - WorldAirTraffic0-24h.wmv (00/14) Jess Lurking Aviation Photos 4 August 13th 10 11:57 PM
Assorted Militaria (read the Zero file) - File 35 of 37 - AG-Fighter__47.rar.vol0+1.PAR2 (2/2) Br'er Rabid[_2_] Aviation Photos 0 April 27th 09 01:34 AM
There is NO malware in this zip file - On Topic post of a different type - File 1 of 1 - AmericasSpirit.zip (0/2) Lee[_2_] Aviation Photos 9 October 31st 08 07:51 PM
There is NO malware in this zip file - On Topic post of a differenttype - File 1 of 1 - AmericasSpirit.zip (1/2) Gary R. Schmidt Aviation Photos 3 October 23rd 08 04:49 AM
