fin/wing tanks freezing
Old June 5th 13, 04:41 PM posted to rec.aviation.soaring
Matt Herron Jr.
Default fin/wing tanks freezing
Can anyone share some wisdom on using water at high elevations for long durations? How do you know your fin or wing tanks will not freeze? If I am at 18K for 6 hrs in the Sierras, I really don't want my vertical stab splitting open in flight. Has this ever happened? Any guidance would be appreciated.
Matt
Old June 5th 13, 04:59 PM posted to rec.aviation.soaring
jfitch
Matt
I know in the Duo Discus I used to own (part of) the OAT gage was a required instrument just for this reason. It will take a long time for a wing tank, or even a fin tank to freeze. But we did have an incident where a dribbling leak from the fin tank collected in the rudder counterbalance and froze, freezing the rudder solid. This was on a day when the return from Mt. Whitney to Truckee was a no-turn romp at 17,999 ft. It did finally unfreeze as the Duo descended on final. I don't know of anyone who has had a fin tank freeze.
Old June 5th 13, 05:10 PM posted to rec.aviation.soaring
Peter Scholz[_3_]
Matt
They will freeze. Depending on the layout of the tanks, it may do damage
to the tank or wing structure.
If you fly in air mass below freezing point, either
- do not use water ballast
- or add the appropriate amount of antifreeze to the water.
If possible, you can land with the ballast water and then recollect the
antifreeze mixture. I know of several pilots that have done it that way.
Peter Scholz
ASW24 JE
Old June 5th 13, 05:23 PM posted to rec.aviation.soaring
Matt Herron Jr.
I fly a Ventus C with integral tanks (no Bags) any issues with antifreeze and carbon/fiberglass tanks? What would be the recommended amount? Sounds like an environmental hazard to dump, and I certainly dont want to land wet unless I have to.
I have had issues with the Ventus fully loaded with water where the flaps seem to stick a bit. Not sure if it was a freezing leak or what, but was a little scary. Frozen rudder must not have been too fun.
Matt
Old June 5th 13, 05:51 PM posted to rec.aviation.soaring
Croft Brown
It is folly to fly at high altitudes with water ballast on board. It is a
requirement to have an outside air temp gauge if your sailplane has water
tanks fitted (even if they are never used). I am amazed that this question
has even been posted.
cb
Sounds
wet
unless I have to.
a
Matt
Old June 5th 13, 09:46 PM posted to rec.aviation.soaring
jfitch
In the Sierra, we fly every day at high altitudes with water ballast on board. Literally 10s of thousands of flights. 18,000 feet is common, 24,000 not unusual, OAT of around 20 F is normal. I have never heard of anyone that filled his tanks with antifreeze. Routinely landing with full tanks would be a far greater hazard. I suppose if you were contemplating a dawn-to-dusk record winter wave flight, it might be worth considering.
But perhaps we are all guilty of folly.
Old June 6th 13, 02:32 PM posted to rec.aviation.soaring
TravisBrown73[_2_]
On Wednesday, June 5, 2013 9:51:04 AM UTC-7, Croft Brown wrote:
....... I am amazed that this question has even been posted......
cb
You could focus on coaching instead of deriding a fella for asking a genuine question.
Sounds
wet
unless I have to.
a
Matt
Old June 6th 13, 06:23 PM posted to rec.aviation.soaring
Croft Brown
Of course your right. We must focus on coaching. Read the flight manual
section on water ballast.
cb
cb
genuine question.
antifreeze
Sounds
land
wet
unless I have to.
flaps
was
a
Matt
Old June 5th 13, 06:10 PM posted to rec.aviation.soaring
Bob Kuykendall
On Jun 5, 9:23*am, "Matt Herron Jr." wrote:
I fly a Ventus C with integral tanks (no Bags) any issues with antifreeze and carbon/fiberglass tanks? *What would be the recommended amount? *Sounds like an environmental hazard to dump, and I certainly dont want to land wet unless I have to.
I have had issues with the Ventus fully loaded with water where the flaps seem to stick a bit. *Not sure if it was a freezing leak or what, but was a little scary. *Frozen rudder must not have been too fun.
Matt
The factory probably has a recommended antifreeze agent; if so, use
that. In the absence of such a recommendation, I would probably use
propylene glycol-based antifreeze intended for winterizing RVs and
cabins; it is pretty safe stuff. I would be very wary about using
ethylene glycol antifreeze unless I knew for certain that the ballast
system bags, tanks, linings, plumbing, seals, and valves were all
compatible with it. And even then I probably wouldn't use it for
environmental reasons.
Thanks, Bob K.
Old June 5th 13, 09:35 PM posted to rec.aviation.soaring
Peter Thomas[_2_]
even if it doesnt freeze in the tanks, it may well when dumped. I
know of a case of this in the uk, the ice buildup at the base of the
fin apparently made things interesting.
Anyone understand the the issues of high altitude limiting speeds
and a ballasted glider?
for long
dur=
If I am
a=
splitt=
be
apprecia=
ted.
Matt
Now we have freezing rain! GARY BOGGS Soaring 9 January 21st 12 02:28 PM
Schleicher wing tanks Andy[_1_] Soaring 5 April 22nd 09 07:00 PM
Screen freezing. W.Lindsay Simulators 3 May 10th 06 09:03 PM
Drains in Wing Tanks flybynightkarmarepair Home Built 9 April 8th 06 05:32 PM
GPS_LOG freezing and freezing cernauta Soaring 4 May 8th 05 06:39 PM
