Grob drop off tail dolly
Old June 7th 13, 03:02 PM posted to rec.aviation.soaring
Greg Delp
Default Grob drop off tail dolly
Has anyone modified one of the Grob pin and socket drop off tail dollies for use with a tow bar? I'm worried that the stresses from towing on uneven ground/grass may cause issues with cracking the socket portion in the fuselage. Of course building or finding a regular wrap around dolly is an option.
Old June 7th 13, 03:22 PM posted to rec.aviation.soaring
Ralph Jones[_3_]
On Fri, 7 Jun 2013 07:02:00 -0700 (PDT), Greg Delp
True story: My late partner Morgan was staged for a contest launch in
our Astir-CS, and referring to the tailwheel hole in our customary
scatological manner, he said "Tape up my ***hole!" Unfortunately, he
had a hot mike...
Old June 7th 13, 03:26 PM posted to rec.aviation.soaring
Old June 12th 13, 01:29 PM posted to rec.aviation.soaring
Old June 12th 13, 04:04 PM posted to rec.aviation.soaring
Greg Delp
Did the one you make have a wheel or wheels on the tow bar portion? That sounds like a good alternative.If the tow bar portion was strong enough to prevent any leaning of the post section it would evenly distribute all the stress along the entire wall of the socket in the tail.
Old June 12th 13, 07:38 PM posted to rec.aviation.soaring
Hi Greg! No wheel, the towbar is attached to the fuselage with the pin and the belt, then lifted onto the tow coupling of the car. Of course this does produce some stress on the bar and it has to be solid and well made (guess how I learned).
Old June 12th 13, 11:29 PM posted to rec.aviation.soaring
Greg,
The tow bar I made just attatches to the axle of the origninal 'Wheel-on-a-post'.
Grob 103 Tail Dolly Roger Fowler[_2_] Soaring 3 September 1st 10 02:21 AM
Wanted: Tail Dolly for Grob 102 Club III Mitch Deutsch Soaring 2 May 4th 10 09:05 PM
LS4 tail dolly Leigh Soaring 0 May 30th 08 02:02 AM
WTB: used tail dolly David Campbell Soaring 5 April 17th 06 03:19 PM
L-23 tail dolly Mark Zivley Soaring 1 November 27th 04 11:16 AM
