Of tow hooks and wheel brakes
Old June 9th 13, 06:53 PM posted to rec.aviation.soaring
Default Of tow hooks and wheel brakes
Of tow hooks and brakes
The Region 9 contest is done and of course today is the most wind free day since the contest started. To say the contest weather was breezy is putting it mildly.
The wind put a severe strain on gliders and pilot skill. The pilot skill was there but I think in several cases the pilots had the deck stacked against them right from the start by their gliders.
Why anyone is still using only a center of gravity tow hook is beyond my understanding. The same goes for original weak Tost wheel brakes.
Alternatives are available for almost every model glider now. Even the original Tost brake now has a hydraulic actuator available. I believe there are forward tow hook installations, factory approved, for every model glider that was here.
Expensive? What was the cost of attending the contest? What is the cost of repairing your glider not to mention the loss of use while it is being repaired? What about the emotional cost as you veer off the runway and hope the resulting ground loop does not break your tail boom?
We all talk a lot about safety, safety is not cheap. Soaring is not cheap, who said it was supposed to be? Lets put our money where our mouth is. Make you glider safer.
Will the insurance companies wake up one day and realize there are more launch accidents and claims with C.G. hook equipped gliders?
I may be hurting my bottom line as I do operate a glider repair shop at Moriarty, but I am sick of seeing needless damage done to gliders.
Robert Mudd
Composite Aircraft Repair LLC
Old June 9th 13, 08:28 PM posted to rec.aviation.soaring
Bill D
Yep, CG hooks are for winch launch - nose hooks for aero tow. Bad things happen the other way around. You'll probably want to do winch launches eventually so keep the CG hook, just add a nose hook.
Drum brakes can work like disks if you let Vintage Brake do their magic. http://www.vintagebrake.com/
Robert Mudd
Old June 9th 13, 09:45 PM posted to rec.aviation.soaring
slbair
What is the approximate cost of adding an aero tow hook to a sailplane that is designed for it but does not have one?
Old June 9th 13, 10:13 PM posted to rec.aviation.soaring
Tony[_5_]
Pulling the release before things get out of hand is pretty cheap, like I did on day 2. Brakes are like Goldilocks if you want to stay out of the repair shop. Too weak and here comes the fence at the end of that field. Too strong and there's a hole in your nose after the wheels lock up.
Old June 9th 13, 11:02 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
d=
repa=
st=
Yep simple rule of thumb. If your glider has a nosewheel then fit a brake
as strong as you like. If you do not have a nosewheel, as in most single
seaters fitting a strong brake is really a waste of time and money because
you cannot use it. Even the "weak" brakes fitted to gliders such as the
discus can only be used with care.
Old June 9th 13, 11:44 PM posted to rec.aviation.soaring
BobW
Having once owned a tail-dragging glider with "world's best brake" I can vouch
that having an "overly powerful" *and* easily modulatable brake is a wonderful
combination. (It was a hydraulically-actuated drum brake on a homebuilt HP-14.)
It was powerful enough to put the plane on its nose, while simultaneously
sufficiently modulatable as to (easily) permit braking heavy enough to lift
the tail without pitching onto the nose. Combined with world's most powerful
landing flaps, the plane was a joy to land, despite its Vee tail-feathers and
veering into crosswind tendencies (in which case I generally angled into the
wind as much as practicable, touched down with minimal safe energy and fell
more in love with large deflection flaps and the superb wheel brake)...
Bob W.
Old June 9th 13, 11:59 PM posted to rec.aviation.soaring
On Sunday, June 9, 2013 4:02:31 PM UTC-6, Don Johnstone wrote:
If you do not have a nosewheel, as in most single seaters fitting a strong brake is really a waste of time and money because you cannot use it. Even the "weak" brakes fitted to gliders such as the discus can only be used with care.
You can not use the breaking power you do not have, but you can modulate the extra breaking power you do have. Better a scraped nose than a busted glider. And having a nose hook also lowers the odds of having to release and use all the braking power.
Having flown tail wheel gliders with too little and with too much power I prefer the one with too much braking power.
Robert Mudd
cobra wheel bearings and brakes [email protected] Soaring 4 August 13th 12 11:21 PM
OTTFUR HOOKS Paul Moslin Soaring 0 January 5th 09 08:15 PM
Glider Wheel Brakes [email protected] Soaring 20 May 31st 08 02:42 AM
Wheel, axles and brakes for sale. [email protected] Home Built 0 December 5th 05 02:51 PM
BGA Tech. News, Wheel brakes. W.J. \(Bill\) Dean \(U.K.\). Soaring 8 May 31st 05 01:55 PM
