To VOR or not to VOR?
Old June 12th 13, 06:34 PM posted to rec.aviation.soaring
Thomas Van de Velde
Default To VOR or not to VOR?
The question on whether VOR/ADF is a required subject for FAA glider ratings has come up on this mailing list but without a conclusive answer. I've recapped another recent discussion along with input from the FAA on my blog:
http://flightbit.com/2013/06/11/to-vor-or-not-to-vor/
I hope this clarifies the confusion on the subject.
Thomas
Old June 12th 13, 08:15 PM posted to rec.aviation.soaring
Is this only for the private pilot rating or does it apply to the
commercial pilot rating as well?
As an aside question, has anyone used exams4pilots.org to prepare for
the commercial glider pilot rating? I have gone through several
practice tests and noticed that several questions are given that have
nothing to do with glider flying. As a commercial glider pilot why do
I care about fuel burn, manifold pressure and how the engine works? It
is a convenient free website, but as it relates to preparing for the
commercial glider pilot exam, the website leaves a bit to be desired.
Old June 12th 13, 10:35 PM posted to rec.aviation.soaring
Doug Mueller
prepare for
have
do
works? It
desired.
Recently I was informed that the FAA had decided to change all FAA
airman testing requirements. Although not published, the FAA made
a determination that an airman seeking a rating should be familiar
with the knowledge base that is applicable to the appropriate rating
sought. So now when an airman tests for a written they will be
tested for the questions in that apply to the category of GLI,ALL for
glider ratings. This comes from my sources in Oklahoma City. I
managed to find out first hand when seeking my CFI-G written last
fall. The test changed in October last year. To my knowledge that
mind set has not changed. When you study the questions make sure
you study the questions that are classified as ALL as well as GLI.
Old June 12th 13, 11:00 PM posted to rec.aviation.soaring
noel.wade
the commercial glider pilot rating? *I have gone through several
nothing to do with glider flying. *As a commercial glider pilot why do
Are you sure you changed the test-type and saved that change? You may
need to re-select the type of exam you want, each time you visit or
with each computer you use to access the site.
And yes, I saw some powered-airplane-type questions on my commercial
glider written exam, back when I took it in 2010. Not sure about
changes in the last 2 years, though.
--Noel
Old June 13th 13, 01:08 AM posted to rec.aviation.soaring
GM
--Noel
Took my Commercial Glider knowledge written test a couple of weeks ago and there were quite a number of radio-nav questions in it. The only logic explanation I have for this is that one could fly a Grob G109, Stemme S10, Ximango, HK36, etc. with a glider license yet have a near complete IFR panel. I have yet to find an HSI in a pure glider ;-)
GM
Old July 2nd 13, 05:20 AM posted to rec.aviation.soaring
bill palmer
Perhaps it's because once you pass the commercial written, you're done.
But the author of the interpretation should read the first part of the rule:
" ...on the aeronautical knowledge areas of paragraph (b) of this section THAT APPLY TO THE AIRCRAFT CATEGORY AND CLASS RATING SOUGHT..
Thomas
Old July 2nd 13, 04:25 PM posted to rec.aviation.soaring
Thin Air
I took the private glider pilot test just a few weeks ago (June 2013) and there are still plenty of questions related to radio/nav/vor on the test.
I find it entertaining (in a sad sort of way) that the FAA will 'definitively' answer questions about what is in the test without knowing what is in the test.
JB
Old July 2nd 13, 04:27 PM posted to rec.aviation.soaring
Thin Air
Thomas
It doesn't, because the answers they gave you to your question are wrong.
