News about Pittsburgh Soaring Club
Old June 20th 13, 01:38 PM posted to rec.aviation.soaring
Tom K (ES)
Default News about Pittsburgh Soaring Club
http://www.thealmanac.net/article/20...5#.UcL21Plwp8E
Old June 20th 13, 03:03 PM posted to rec.aviation.soaring
JohnDeRosa
"...gliders, soarers or soarplanes..."
OUCH!
Old June 20th 13, 06:13 PM posted to rec.aviation.soaring
GM
OUCH!
“It appeals to older folks,”
Must be true - we clearly show that on the 'Let's go gliding' banners and stickers. The only reinforcement of that statement would have been two oxygen cannulas stuck in their noses!
It would be great if the 'Journalist' would run their articles past someone with first-hand knowledge to filter out some of the garbage which I am sure wasn't said as printed!
'GM' - a former member of the Pittsburgh Soaring Club
Old June 20th 13, 10:29 PM posted to rec.aviation.soaring
son_of_flubber
"As far as flying goes, Wilson says it’s very safe."
On the off chance that Wilson did in fact say this, I cringe. A few people said similar things to me when I first started to fly, so I'll assume that it was said.
How about saying this instead, "Flying in a glider is inherently dangerous, but we do a lot to make it safer."
Is there no consensus that it is problematic to misrepresent or discount the inherent dangers of soaring? The moral (and legal) ramifications of a newcomer having an accident after being told that the sport is safe are grave..
Admitting that the sport is inherently dangerous and having an adult conversation about those dangers before a new person hops into the glider is not going to scare away the good candidates. I think that the opposite may be true.
Old June 21st 13, 07:13 AM posted to rec.aviation.soaring
Alan[_6_]
In article son_of_flubber writes:
http://www.thealmanac.net/article/20...0619935#.UcL2=
1Plwp8E
"As far as flying goes, Wilson says it=92s very safe."
On the off chance that Wilson did in fact say this, I cringe. A few people=
said similar things to me when I first started to fly, so I'll assume that=
it was said.
How about saying this instead, "Flying in a glider is inherently dangerous,=
Is there no consensus that it is problematic to misrepresent or discount th=
e inherent dangers of soaring? The moral (and legal) ramifications of a ne=
wcomer having an accident after being told that the sport is safe are grave=
Admitting that the sport is inherently dangerous and having an adult conver=
sation about those dangers before a new person hops into the glider is not =
going to scare away the good candidates. I think that the opposite may be =
true.
I'll disagree.
If flying in a glider is inherently dangerous, then you are doing
something wrong.
If folks had been telling me that flying gliders was inherently
dangerous before I started, I would have gotten back into my cessna
and flown (safely) away.
Aviation may be unforgiving of carelessness, incapacity, or neglect;
but it should not be inherently dangerous.
I read of people doing dangerous things in gliders, such as:
a. Ignoring 91.111(a) in thermals.
If another aircraft suddenly changes direction of flight, you
should have been far enough away that it didn't cause a problem.
b. Ignoring 91.155(a) particularly cloud clearance requirements.
If you are "at cloudbase", it sounds like you have busted this
one.
c. Ignoring 91.119(c) with a high speed pass over the airport
on return. It is not "necessary for takeoff or landing".
If you cannot land without it, I can refer you to some good
instructors who can show you how.
The same may apply to some ridge flying.
I'll say it again. If you believe that your glider flying is inherently
dangerous, get some better instruction.
Alan
soaring club reporter arturo Soaring 2 June 30th 07 01:15 PM
XC in club ships & other great US news SAM 303a Soaring 7 October 7th 06 05:21 AM
Japan Soaring Club? Tim Maw Soaring 0 October 11th 04 12:53 PM
Soaring Club in Naples FL? Mike Schumann Soaring 5 September 13th 04 11:01 PM
Bad news for our flying club Paul Tomblin Piloting 29 May 27th 04 04:27 PM
