Official observer question
Old June 25th 13, 12:57 PM posted to rec.aviation.soaring
Larry Suter
Default Official observer question
The SSA form wants me to check a box saying "File security checked using proper software". How on earth would I go about doing that for a Nano flight recorder?
FWIW, I downloaded the pilot's file from the Nano, looked at it on SeeYou and it all seems fine to me.
Larry
Old June 25th 13, 01:09 PM posted to rec.aviation.soaring
Greg Delp
Larry
You need to download the IGC LXNAV DLL Shell file discussed in the FAI approval document for the Nano. It can be found here http://www.fai.org/igc-documents
Old June 26th 13, 03:28 PM posted to rec.aviation.soaring
Papa3[_2_]
Larry
Hi Larry,
Expanding a little bit on what Greg wrote below. Part of the OO's job is to make sure that nobody tampered with the file at some point and/or that the device itself hasn't been tampered with. The way the IGC approved FRs do this is through a security "stamp" that's added to the IGC file. It's known as the G-Record, and the manufacturer has to provide an algorithm to decode that G-Record. SeeYou has the ability to run a security check; you may (or may not) have that feature turned on. You would see it on the Analysis page (don't have my laptop with SeeYou loaded with me today, so doing this from memory). If it says "security unknown", you can check it with (I beleive) the Edit function.
The "official" way to do this is to run the Vali program as supplied by the manufacturer. I believe LX is actually pointing you to a copy of the IGC Shell program with their vali DLL he
http://www.lxnav.com/downloads/softw...ation-tool.zip
The really official way is to read the NANO approval doc and do what it says, but that's likely to point you back to the above.
Role of the observer in FAA Alex Potter Naval Aviation 5 November 30th 10 11:02 PM
Becoming an Official Observer Wojciech Scigala Soaring 4 March 16th 09 12:17 AM
Aviation Observer Wings Question - Do they still use them ? R. Scott Naval Aviation 8 July 15th 07 06:32 AM
Col. Robert Bowman, PhD, U.S. Air Force (ret) - Director of Advanced Space Programs Development under Presidents Ford and Carter. "A lot of these pieces of information, taken together, prove that the official story, the official conspiracy theor Custard Cream Naval Aviation 10 July 14th 07 06:51 PM
Runway observer Jim Culp Soaring 8 August 20th 03 04:33 AM
