Landing Gear Issues on LS3
Old July 1st 13, 04:38 AM posted to rec.aviation.soaring
Default Landing Gear Issues on LS3
So the other day, I pull my fuselage out of the trailer and the gear free falls out of the well. Turns out, the 400N strut pulled itself out of the fitting on the end.
I have a new strut, but trying to figure out how to install it. I have adjusted the turn buckle so that there about an 1/2" compression on the strut when the gear is extended. However, during retraction, the strut fully extends and seems to be pulled to get the gear up. Seems to me this may cause the same kind of failure, where the fitting on the end gets pulled out. Compression good, tension bad.
Anyone have experience with replacing the 400n strut for the landing gear on an LS3?
I have photos and a video if you think they might help the conversation.
Andrew - 3T
Old July 1st 13, 02:00 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Andrew - 3T
Something not right here.............are you sure you have the correct replacement strut? Just checked my LS-3 manual and didn't find the strut mentioned. You might check another LS-3 to see if your strut is the same. The strut should apply pressure when gear is up and down.
JJ
DG 300 landing gear PK Soaring 9 February 6th 12 06:42 PM
767 landing without landing gear in Warsaw ASM Soaring 10 November 3rd 11 04:53 PM
A Jet Blue Aircraft Landing with Sideway Landing-Gear Lufthansi Piloting 18 July 19th 06 05:13 AM
A Jet Blue Aircraft Landing with Sideway Landing-Gear Hansi Instrument Flight Rules 1 July 17th 06 04:01 AM
Landing Gear Lou Parker Home Built 2 April 11th 04 04:08 AM
