DeLorme inReach SE units now in stock
Old July 3rd 13, 06:31 PM posted to rec.aviation.soaring
Paul Remde
Default DeLorme inReach SE units now in stock
Hi,
After delays of a few months - I finally have DeLorme inReach SE units in
stock.
http://www.cumulus-soaring.com/delorme.htm
I played with mine a lot yesterday and I'm very impressed. It is very easy
to send one of 3 pre-defined messages. it is also possible to send text
messages to email addresses or cell phones using the unit's virtual
keyboard. It can also be connected to a smartphone if you want to view
detailed maps. Using a smartphone also makes it easier to send messages.
But a smartphones is not required at all.
Below is a list of the advantages the inReach SE has over competitive
products.
- Track points include not only GPS position, but also altitude,
groundspeed, and heading - making it easy for your friends to see whether or
not you are still flying.
- With the optional "Aviation" data plan, the tracking interval can be set
at 1, 1.5, 2, 5, 10, 15, 20, 30, 60, 120 or 240 minutes. Using the 1 minute
tracking interval would make flight following at a soaring contest a lot of
fun. It would enhance safety by reducing the search radius in the event of
an emergency in which the unit stopped transmitting.
- Friends viewing your shared page can "ping" your location (if enabled)
using your MapShare page - even if the unit is not in tracking mode. That
would be handy in an emergency. The unit only needs to be turned-on.
- The tracking can change automatically to a long interval (up to 4 hours)
when not moving and change back to the standard (fast) tracking interval if
you move more than a user-defined distance of 20, 50 or 100 meters (66, 164,
or 328 ft). That reduces the data rate when not in flight - which reduces
the monthly byte usage fees (with aviation data plans).
- Having the antenna on top makes it easy to get a good connection with the
unit in a pouch on your parachute strap.
- Better satellite coverage than competitive products - 100% of the world is
covered
- Friends viewing your shared page can send you a message (if enabled) - If
your inReach is on it will alert you to the reception of the message.
- 2-way messages can be sent to any email address or cell phone (text
message)
- The inReach SE works great with, or without a smartphone connected to it.
Free-form messages can be sent using the virtual keyboard on the inReach SE
or using a connected smartphone. It is easy to put into track mode and send
one of 3 pre-defined messages using the buttons on the front of the unit.
Download free detailed topographical maps to your smartphone (at home) and
navigate using the inReach SE as your GPS data source when out in the field.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
Old July 4th 13, 01:05 AM posted to rec.aviation.soaring
Morgan[_2_]
I must commend you Paul. You really went out of your way to lay out all of the costs in as clear of a way for pilots that I've seen. Delorme should just link to your website for their Aviation plans. Great breakdown.
Morgan
On Wednesday, July 3, 2013 10:31:52 AM UTC-7, Paul Remde wrote:
Hi,
stock.
products.
covered
message)
Good Soaring,
Paul Remde
New DeLorme inReach SE with color screen and virtual keyboard Paul Remde Soaring 0 March 16th 13 02:00 AM
Delorme InReach reporting elevation or altitude ?? [email protected] Soaring 6 March 3rd 13 04:57 PM
DeLorme inReach Paul Remde Soaring 8 February 12th 13 07:26 PM
Any user reports on Delorme Inreach? Steve Koerner Soaring 8 March 16th 12 06:51 PM
More on Delorme InReach Satellite Tracker Frank Paynter[_2_] Soaring 12 October 8th 11 05:50 AM
