Degausser, what is it?
Old March 31st 04, 08:51 PM
Robert M. Gary
Default Degausser, what is it?
It was recommended to me that I should rent a degausser to get my
compass to behave more reasonably. I called a dealership that rents
it, they are asking $50 plus shipping for 1 week's use. They said it
requires power. I'm having trouble invisioning what this thing is. I'm
also curious what it would be like to ship. Is it something big like a
vacuum cleaner?
-Robert
Old March 31st 04, 09:44 PM
John Harlow
It is a freakin coil of wire. If you knew what you were doing, you could
bust open an old computer monitor or TV and take the one which is around the
CRT.
Old April 1st 04, 01:54 AM
jsmith
Not for an airplane!
I suppose the next thing you would say is that it works on any aircraft?
CRT.
Old March 31st 04, 10:11 PM
Rosspilot
It's really a large round electromagnet. I have seen them used to fix color TV
screens.
www.Rosspilot.com
Old March 31st 04, 11:18 PM
Dylan Smith
In article , Robert M. Gary
To find out what one is, if you still have a CRT monitor on your
computer, go into the Setup and look for the degausser, and press it. It
may be represented with a picture of a magnet crossed out - which is
what it does - it demagnetizes the shadow mask (or aperture grill if you
use a Trinitron) in your monitor. Your monitor will go
BBbbbbbBBrbrrrrrrrr! when you hit it, and the picture will wobble around
a lot for a couple of seconds. (Some monitors degauss on power-up, and
that's why they make the noise they do when you turn them on).
I assume they think the steel parts of your plane have become
magnetised.
Dylan Smith, Castletown, Isle of Man
Flying: http://www.dylansmith.net
Frontier Elite Universe: http://www.alioth.net
"Maintain thine airspeed, lest the ground come up and smite thee"
Old April 1st 04, 03:34 AM
Ross Oliver
Go on ebay and buy a "bulk tape eraser" like this one:
http://cgi.ebay.com/ws/eBayISAPI.dll...tegory=48 642
degauss = erase = scramble an orderly magnetic field into a disorderly one
Old April 5th 04, 05:52 PM
Paul Sengupta
"Corky Scott" wrote in message
Robert, during WWII, the Allied response to German magnetic mines
which were laid on the bottom of shallow water passages like the River
Thames, was to degauss the ships. That's right, entire ships. The
ship would be wrapped entirely around with huge electrical cables and
then they would be energized and the ships magnetic field would be
altered enough to avoid setting off the mines. Or so the engineers
calculated anyway. It's still being done according to sources brought
up with a google search. Some ships have permanent degaussing coils
built into the hull and superstructure.
Deja-vu?
http://www.forpilots.com/archive/rec...7/msg18350.htm
Read back in the thread for more info...
Paul
Old April 5th 04, 02:51 AM
Big John
Brian
Same problem I had with my Mk20C (turbo normal, manual gear )
Cage is great for safety but hell on compass headings.
Big John
On 1 Apr 2004 07:09:40 -0800, (Brian Cox) wrote:
(Robert M. Gary) wrote in message . com...
vacuum cleaner?
-Robert
I had a problem with the compass in a Mooney M20C. It was also
recommended that I try degaussing the steel cage. I got a lot of
conflicting advice about degaussing. Since I'm based in Colorado, I
also considered the effects of P-static. That is because the compass
errors (approximately 40 degrees) were intermittent. In the end, I
bought a kit of static wicks from Mooney and installed them per STC.
The compass problem was fixed. I haven't seen any other Mooney's in
this area with static wicks, but most all Cessnas have them.
On the price of $50 for one week's use - that sounds about right. It
may be my error, but I'm assuming you have a Mooney, and that the
degausser is avaiable from LASAR (Lake Aero)? Another alternative is
to put a remote compass sensor in the tail and the compass head in the
panel, but that is a bit pricey.
Good luck,
Brian
Former owner M20C
