PowerFlarm Updates
Old August 9th 13, 04:16 PM posted to rec.aviation.soaring
kd6veb
Default PowerFlarm Updates
Hi Gang
I have just updated the firmware on my PowerFlarm portable unit in the Phoenix without problems to version 3.31. Now how do you do the same for the brick and Butterfly display in the DG1001M? I have loaded the new firmware onto a USB memory stick and plugged it in but the unit does not seem to recognize the memory stick. So I must be doing something wrong. Would someone please show me the correct procedure to update the brick's firmware. Thanks..
Dave
Old August 9th 13, 04:23 PM posted to rec.aviation.soaring
Luke Szczepaniak
On 08/09/2013 11:16 AM, kd6veb wrote:
Hi Gang
Dave
Make sure its not a USB3 drive, (USB2 should work) probably best to keep
it to a 2GB size formatted in FAT32. Make sure the file has not been
renamed by your browser when you saved it and its at the root of the drive.
Hope this helps,
Luke
Old August 9th 13, 09:43 PM posted to rec.aviation.soaring
Hi Gang
Dave
Hope this helps,
Luke
Just back from the glider club after upgrading to 3.31
Make sure you hold in the knob on the Butterfly display while turning on power to the PFlarm with the (2GB) memory stick in place. Bingo, it upgrades!
Herb
Old August 10th 13, 06:55 AM posted to rec.aviation.soaring
FirmWare 3.31 is for the PowerFlarm core.
It has nothing to do with the Butterfly display.
So, pushing buttons of the display at power-up is irrelevant for the CORE firmware update.
Holding the display push button down at powerup is only relevant for DISPLAY firmware update or new FlarmNet database upload.
Take a clean USB stick
(as mentioned above, nothing fancy like USB3, a Gazillion GB, properly formatted in FAT32)
Make sure there are no other firmware files (.fw) in the root (top) directory.
Watch the LED on the Core blinking.
When the blinking stops and the standard screen (butterfly with green square GPS and TX boxes) comes up, the process is done.
Old August 12th 13, 02:52 PM posted to rec.aviation.soaring
Dave:
We discovered after a few tries that some USB drives don't work for the ClearNav, and possibly the Power Flarm. Previous posters have mentioned similar problems. In fact ClearNav first sent us a Patriot thumb drive and later told us not to use that make. Go figure! Another thing we discovered is that you cannot download the update on a thumb drive and put it on two devices: download it onto one thumb drive, install it, then download it again and install it on the second device. Fred
PowerFLARM USB 3 cables and ConnectMe to PowerFLARM through V7 Tim Taylor Soaring 20 June 17th 13 05:56 PM
PowerFLARM News Updates on my FLARM web page Paul Remde Soaring 10 March 6th 13 04:50 AM
PowerFLARM updates and installation notes Dave Nadler Soaring 66 June 7th 12 09:10 PM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
More Updates Maple1 Aviation Photos 0 November 4th 07 10:29 PM
