water bag usage
Old August 13th 13, 05:51 PM posted to rec.aviation.soaring
Echo
Default water bag usage
Given the record setting soaring weather in the mid-south and southeast this year, does anyone have any experience inflating their water ballast bags so as to be used for a flotation device? Seems like the only way to use them. That's what they're for right? By the way, how do you thermal in the rain? Has anyone ever calculated a polar for an ASW20 fitted with a float kit? Thanks
E
Old August 13th 13, 07:17 PM posted to rec.aviation.soaring
Peter Scholz[_3_]
E
Actually I did inflate my water bags a couple of years ago to test for
any leaks. I was amazed what 0.2 bar will do to those bags. They could
well have been used to construct a floating device, provided we
wouldhava had a pond around, and more suitable weather (was around
freezing point outside...). And yes, they did hold the pressure for 12
hours, so they're back in the wings now.
Peter Scholz
ASW24 JE
Old August 13th 13, 09:18 PM posted to rec.aviation.soaring
lynn
E
Perhaps filling the hags with helium would be more productive?
Old August 13th 13, 09:24 PM posted to rec.aviation.soaring
lynn
E
Of course I meant BAGS not HAGS, but filling hags with helium would be fun to watch.
Old August 14th 13, 09:43 AM posted to rec.aviation.soaring
kirk.stant
And to listen to!
Kirk
66
Old August 14th 13, 03:42 PM posted to rec.aviation.soaring
Ralph Jones[_3_]
On Tue, 13 Aug 2013 13:18:56 -0700 (PDT), lynn
E
Well, let's see. An AS-W20 holds 120 kg of water, so the volume of the
bags is 120 liters.
The density of sea-level air is 1.28 grams per liter, and helium is
0.179. So the lift you'll get is 120L * (1.28g/L - 0.179g/L)=132.5
grams or about 4.7 ounces.
We'll listen to your voice on the radio and tell you if you have a
helium leak...;-)
(USA) FlarmNet usage 2NO Soaring 15 April 30th 13 11:58 AM
Usage fee process Danny Deger Piloting 3 April 11th 07 08:27 PM
Water, water, everywhere, but none for thirsty wings.... Chris OCallaghan Soaring 0 November 21st 04 03:14 PM
Oil usage GE Owning 14 May 20th 04 07:22 AM
me-109 overall "76" combat usage? old hoodoo Military Aviation 9 December 16th 03 12:55 AM
