which frequencies are all?
Old April 8th 04, 01:45 PM
Arden Prinz
Default which frequencies are all?
I was approaching class C airspace for landing at the primary airport
for which the class C airspace is designated and I listened to the
ATIS. The ATIS said "all frequencies are combined on
TowerFrequency". So I tuned to TowerFrequency and made my radio
call to approach. The response that I got was that I needed to call
approach on the approach frequency. So, I guess that begs the
question ... when the ATIS says "all frequencies are combined", which
frequencies are included in "all frequencies"?
Thank-you in advance.
Old April 8th 04, 02:32 PM
Ryan
I would have done the same thing. Maybe it meant only if you were landing
in the Class C.
"Arden Prinz" wrote in message
om...
Old April 8th 04, 04:07 PM
Steven P. McNicoll
"Ryan" f wrote in message ...
were landing in the Class C.
He was.
Old April 8th 04, 07:58 PM
One's Too Many
This wasn't Abilene TX, was it?
They probably meant tower, ground, and clearance delivery (the
airport-specific channels) were all combined onto the tower frequency.
Approach generally stays on it's own channel, but often approach and
departure get combined too since the same person is handling both.
in the Class C.
om...
Old April 8th 04, 04:06 PM
Steven P. McNicoll
om...
my radio call to approach. The response that I got was that I
needed to call approach on the approach frequency. So, I guess
that begs the question ... when the ATIS says "all frequencies are
combined", which frequencies are included in "all frequencies"?
Based on the tower's reply, it appears "all frequencies" means tower, ground
control, and clearance delivery frequencies. But that doesn't mean your
assumption was unreasonable.
Old April 8th 04, 04:43 PM
TaxSrv
tower, ground
your
A solution requiring no thought is just call approach per normal, and
switch to further freqs as instructed or to just "stay with me," as
happened to me once at big Milwaukee apt at 5AM, from 30 miles out to
all the way to shutdown.
I you happen to know the same guy has been working twr and ground,
after startup, wouldn't you still call on ground freq? Otherwise,
you're setting yourself up for embarrassment if 10 seconds prior, the
ground controller returned from the can, and both positions are back
to normal. Correct?
Fred IF.
Old April 9th 04, 12:38 AM
Arden Prinz
Fred, I want to make the initial call on the proper frequency. When
I've
been on the ground preparing to taxi and I hear on the ATIS that
tower, ground, and clearance are combined on TowerFrequency, then my
initial call has been on the TowerFrequency. Likewise, when I'm on
the ground preparing to taxi, I've hear on the ATIS that all
frequencies are combined on TowerFrequency, then my initial call is
on TowerFrequency. This was the first time I was ever arriving and
heard on the ATIS that all frequencies are combined on
TowerFrequency an it seemed to me like that meant that my initial
call should have been on TowerFrequency.
to normal. Correct?
Hmmmm. I have no insight into who is working where. But if I listen
to the ATIS and it tells me to use a certain frequency, and I use some
other frequencey, then wouldn't that be setting myself up for
embarrassment (they might figure I neglected to listen to the ATIS).
Arden
Old April 9th 04, 01:40 AM
Bill Denton
A few thoughts...
I believe you started with a bad assumption. If you think about it, tower,
ground, clearance, and ATIS are associated with a single airport.
But approach is not associated with any particular airport. Even though a
given approach may serve only one airport, it's not associated with that
airport, it's associated with a center. This is why you may see approach and
departure on the same frequency.
I'm gathering that at the point in your flight where you checked the ATIS,
you would be talking to approach, and you would later switch to tower. Which
is why tower kicked you back to approach.
In the future it would probably help if you could keep in mind who the
service "belongs" to, and that would guide you where to tune for what.
Hope this is useful...
om...
I've
to normal. Correct?
Arden
Old April 9th 04, 02:31 AM
Steven P. McNicoll
"Bill Denton" wrote in message
though a given approach may serve only one airport, it's not
associated with that airport, it's associated with a center.
How so? Approach tends to be located at the airport it was established to
serve, not at a center.
I don't see the connection.
Old April 8th 04, 05:15 PM
Tony Cox
nk.net...
om...
ground
It seems like a misleading ATIS instruction. I've often heard
"Clearance and Ground combined on xx.xx" but never "all
frequencies".
Some pilots - especially newly minted ones - don't realize and
don't really have any reason to suspect that different functions
are handled at different facilities. Publications like "Pilot Guide"
add confusion by listing ATIS, Approach, Tower & Ground in
little boxes for each airport. Who, without extra knowledge, would
suspect that "Approach" is handled by a different facility?
Arden's question isn't easy to answer anyway. If I were approaching
Monterrey (MTR), class C, approach is handled by a facility in
the tower on the floor below the guys looking out of the window.
If I heard "all frequencies" from MTR, I'd assume it means approach
too.
Scanner frequencies for Oshkosh? Greg General Aviation 1 July 21st 04 04:40 PM
Meaning of "IC" on KPHL Frequencies? [email protected] Instrument Flight Rules 2 April 26th 04 04:16 PM
Howie Keefe's Topo Atlas/WAC charts & frequencies Mark Piloting 10 December 1st 03 02:36 PM
Approach Control Frequencies John General Aviation 5 October 18th 03 09:30 AM
Approach Control Frequencies John Owning 10 October 5th 03 12:16 PM
